[RESOLVED] tis-chrome x86 package
Yoann
Registration: July 24, 2019 - 09:39
July 24, 2019 - 09:49
Could there be a problem with the package? tis-chrome 32-bit available in the repository?
In the file setup.pythe MSI file GoogleChromeStandaloneEnterprise64-fr.msi is referenced instead of the file GoogleChromeStandaloneEnterprise32-fr.msi (lines 27 and 35 in the function install) :
install_msi_if_needed('GoogleChromeStandaloneEnterprise64-fr.msi',min_version=versionpaquet,killbefore='chrome.exe',get_version=getversionchrome)
THANKS,
Sincerely
WAPT Community 1.8
July 24, 2019 - 4:07 PM
Hello Yoann,
Yoann wrote: July 24, 2019 - 09:49 Could there be a problem with the package? tis-chrome 32-bit available in the repository?
Yes, there is a bug. I'll check with Kevin to fix it quickly. Thanks for the information.
kguerineau
Registration: March 6, 2018 - 4:28 PM
July 24, 2019 - 5:02 PM
thank you for your report. I have just corrected the package: https://store.wapt.fr/store/details-tis ... D_all.wapt.
Have a good day.
Yoann
July 25, 2019 - 08:03
it works, thank you.
Best regards.
WAPT Community 1.8
