I'm looking for a tutorial on creating a WAPT Office 2013 package. I'd like to know the exact steps to follow. I think there are some modifications to make to the setup.py script. There's a template script for making these changes.
Are there any other modifications, like a timeout setting or anything else?
I don't know much about scripting languages.
Any help would be greatly appreciated!
Thanks in advance.
Jonathan
creating MS-Office 2013 package
- WAPT Expert
there was a topic on the Wapt mailing list:
"[Wapt] Microsoft Office Package"
here: http://lists.tranquil.it/pipermail/wapt ... hread.html
Thanks for the links!
I tried modifying my setup.py file by using a script (originally designed for standard MS-Office 2013) adapted for MS-Office 2013 Professional. I created the wapt package and uploaded it to our private repository. Then, I deployed it to a test computer. The package loads correctly, but during installation (which takes some time), it reports errors and fails to install.
I think I'm missing some elements in my script. Furthermore, I'd like to integrate a VBScript to activate KMS and the license.
Could you provide me with the necessary information (the "errors" or "missing elements") to successfully complete the installation? Thank you.
I'm attaching screenshots.
Best regards,
Jonathan, LPC2E
Best regards,
Jonathan, LPC2E
- Attachments
- folder tis-msoffice-wapt.JPG (122.85 KB) Viewed 10650 times
- control msoffice.JPG (106.36 KB) Viewed 10650 times
- setup.py msoffice1.JPG (174.19 KB) Viewed 10650 times
- WAPT Expert
Good morning
You are missing the silent.msp repair.xml and uninstall.xml files in your package dev folder.
Create the silent.msp file using the command c:\waptdev\my-msoffice-proplus-wapt\setup.exe /admin
Add well SETUP_REBOOT Never when creating the msp file, as in this link:
http://www.adminarsenal.com/admin-arsen ... installation
The content of the XML files is as follows:
The product needs to be modified depending on the version
The uninstall strings are not in the correct location; the lines should be present in `def uninstall():` or in an `uninstallstring` with program files variables
The repair is not mandatory
Alternatively, you can use this example package:
http://wapt.lesfourmisduweb.org/wapt/sm ... 0_all.wapt
You will need to slightly modify the package if you wish to use a version other than the 2013 pro plus.
<Configuration Product="ProPlus">
<Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" />
<Setting Id="SETUP_REBOOT" Value="NEVER" />
</Configuration>
Having followed the steps carefully, I get an error during installation: PackageEntry "packagename" unavailable. And the interface remains frozen on the package installation screen.
I also tried retrieving the file from the link posted above, but I still encounter the same problem.
I would like to point out that I only succeeded in the installation once, by modifying the setup.py file like this:
But afterwards it was impossible to get it working again.
print('installing my-msoffice2013')
run(r'"silent.msp"')
- WAPT Expert
Are you getting
`PackageEntry "packagename" unavailable`
in PyScripter?
in PyScripter?
Thank you for your quick response.
I'm getting an error on the WAPT console while monitoring the task execution.
I get the message: "installing 'package name'" for a while, without any installation taking place on the client, and then the message: "PackageEntry 'package name' unavailable" appears.
- WAPT Expert
Could you please send a screenshot of the console as shown in the attached image?
Could you also confirm that the package appears correctly in "private repository"?
- Attachments
- Capture.PNG (94.68 KB) Viewed 10612 times
- WAPT Expert
If it does not appear in the private repository (or at least the correct version), it is surely because there was a problem during the upload.
Indeed, uploading packages to the wapt server can cause problems when the package is of a significant size (which is often the case for Microsoft Office).
For a Linux server:
You can transfer your wapt package (it is located in c:\waptdev\my-msoffice-wapt.wapt if the package has already been built)
You can transfer it using WinSCP to /var/www/wapt
Then do the following:
Then do this:
This will regenerate the file http://wapt/wapt/Packages including the packages present in the directory http://wapt/wapt
Under a Wapt Windows server:
You can transfer it to the server in c:\wapt\waptserver\repository\wapt
Then launch:
For a Linux server:
chown wapt:www-data /var/www/wapt/my-msoffice-wapt.waptCode: Select all
/usr/bin/python /opt/wapt/wapt-scanpackages.py /var/www/waptUnder a Wapt Windows server:
Then launch:
wapt-get update-packages c:\wapt\waptserver\repository\wapt
