- WAPT Server version: 1.7.4
- WAPT Agent version: 1.7.4.6165
- Server OS: Debian Stretch (9.9)
- Windows 10 administration machine operating system/package creation
We have just updated our server (1.6 => 1.7).
We are experiencing a problem with the package update waptupgrade.
We can generate it and upload it to the server without any problem.
When we attempt an update on a client (W10):
id;Description;Résumé;Heure de début;Traces;Créé par
22;Installation of iut-waptupgrade(=1.7.4.6165-25) (task #22);"Exception: Erreur lors de l'installation de [u'iut-waptupgrade(=1.7.4.6165-25)']: erreurs dans les paquets [[(u'https://waptserver/wapt/iut-waptupgrade_1.7.4.6165-25_all.wapt', '404 Client Error: Not Found for url: https://waptserver/wapt/iut-waptupgrade_1.7.4.6165-25_all.wapt'), None], [u'iut-waptupgrade(=1.7.4.6165-25)', PackageEntry(u'iut-waptupgrade',u'1.7.4.6165-25') , u'Traceback (most recent call last):\n File ""C:\\Program Files (x86)\\wapt\\common.py"", line 4367, in install\n raise EWaptDownloadError(\'Package file %s not downloaded properly.\' % p.filename)\nEWaptDownloadError: Package file iut-waptupgrade_1.7.4.6165-25_all.wapt not downloaded properly.\n']]";2019-08-28T15:38:36.069000;"Traceback (most recent call last):
File ""C:\Program Files (x86)\wapt\waptservice\service.py"", line 1374, in run
self.running_task.run()
File ""C:\Program Files (x86)\wapt\waptservice\waptservice_common.py"", line 515, in run
self._run()
File ""C:\Program Files (x86)\wapt\waptservice\waptservice_common.py"", line 960, in _run
self._run()
";orga
waptserver:/var/www/wapt # ls -al iut-wapt*
-rw-r--r-- 1 wapt www-data 27125044 août 28 15:37 iut-waptupgrade_1.7.4.6165-25.wapt
Amazing, isn't it?
