Hello, using the package creation wizard, I select my .exe file, click Continue, PyScripter opens, I build it, and the package is created. So far, so good.
Then this error appears:
Done Uploading c:\waptdev\ray-CrossPC_22.0.2.0-1_all.wapt
FATAL ERROR: HTTPError: 500 Server Error: for url: https://172.23.197.239/api/v3/upload_packages
Exit code: 3
What does this mean and how can I fix it?
Thank you
error at the end of a build
To elaborate, in the console/tools/preferences, when I check "Verify the server's HTTPS certificate", it shows an access error on both the repository and the server: 14090086:SSLRoutines:SSL3-get-...(out of windows)
Server 1.7.4 - Win7 - Waiting for a Debian VM provided by TiT...
Win7 console - pyscripter 3.4.1
- WAPT Expert
Error 500 is a broad error.
Is it a large packet?
Be careful with the HTTPS certificate verification in the console!
You should only enable it if your configuration is correct (server and certificate bundle!).
- WAPT Expert
Hmm... could you give us the Wapt server logs?
No, I can no longer launch the console; I get
the same message as mentioned above after checking the "verify the server's HTTPS certificate" option.
- WAPT Expert
Did you uncheck the box?
