Private key error during import
tice
Registration: March 16, 2018 - 11:44
September 24, 2019 - 2:09 PM
Hello, after generating the .wapt file, I try to import it via the console and I consistently get the following error:
EWaptPackageSignError: no matching private key found for signing using certificate SSL certificate cn="mycertificate".
I've tried with several different certificates I have, and none of them match :(
the indexes.
(Information in signature)
Server 1.7.4 - Win7 - Waiting for a Debian VM provided by TiT...
Win7 console - pyscripter 3.4.1
September 25, 2019 - 00:07
the private key must be right next to the selected certificate.
tice
September 26, 2019 - 10:05 AM
Yet that is indeed the case.
Here's what I have in C:\Program Files (x86)\wapt\private
wapt certif.JPG (25.45 KB) Viewed 18750 times
and in SSL:
wapt certifssl.JPG (18.97 KB) Viewed 18750 times
September 26, 2019 - 11:08
You've confused
C:\Program Files (x86)\wapt\private with the agent certificates folder, which is for internal Wapt operation.
This folder should be ignored.
Your private key is most likely located in
C:\private.
tice
September 26, 2019 - 11:25
The previous captures were on the client machine with a console.
On the server machine I have this:
wapt certifSrv.JPG (13.67 KB) Viewed 18738 times
When generating a packet, do you need to use the server's certificate?
September 26, 2019 - 12:01
There are a lot of files in c:\private.
You generated several keys???
I don't know which one is the correct key...
Only leave the correct keys in c:\private.
Your agent apparently only accepts keys ending in "ray".
Keep only ray-2019 and ray.pem in the folder.
Back up your data before deleting the other keys...
tice
September 26, 2019 - 12:19
Okay, and what do I need for the console unit?
tice
September 26, 2019 - 12:50
wasted an hour struggling with certificates and keys. :(
I still don't understand what's needed on the console, even after rereading the documentation and regenerating the key/certificate.
Is there a way to work without it? Secure software is great, but if it doesn't work, it's useless.
cfargues
Registration: May 19, 2016 - 3:12 p.m.
September 26, 2019 - 5:40 PM
Hello tice,
Certificate-based operation is at the heart of WAPT; it's what allows us to control access to the deployment on your network.
Without certificates, anyone could deploy anything on your network, which is precisely the situation we want to avoid with a tool like WAPT.
We understand that this operation may seem cumbersome, which is why we strive to maintain comprehensive documentation on this topic, available at https://www.wapt.fr/fr/doc/wapt-configu ... index.html.
Regarding your issue, the best advice I can give you is to reread the documentation, verifying at each step that everything is correct in your installation. Since we don't have access to your WAPT infrastructure, it's difficult for us to determine the best way to assist you.
I invite you to contact the sales department at +33 2 40 97 57 55 to discuss a potential support contract (our prices are very affordable) so we can best assist you.
Have a good day,
Camille
Camille FARGUES,
Account Manager
