[RESOLVED] No more packets and error message
Robin
Registration: Sep 27, 2019 - 11:55
October 4, 2019 - 10:59
Hello everyone,
I wanted to import a package into my private repository. The package was LibreOffice, which is about 250MB.
The upload crashed at around 50% with a message saying the server was no longer responding. My Wapt server crashes every time; I've tested it twice.
I restarted my server and console. I no longer have any packages and I get an error message when I refresh the packages available in my groups and repository.
WAPT Server version: 1.7.4 - OS Linux debian 9.11 stretch
OS Windows 10 (administration)
Thanks in advance
October 4, 2019 - 11:18
Hello, I can give you the procedure to fix the problem, but I'm missing some information (see forum rules at the top of the page)
Robin
October 4, 2019 - 2:33 PM
sfonteneau wrote: ↑Oct 4, 2019 - 11:18 AM Hello, I can give you the procedure to fix the problem, but I'm missing some information (see forum rules at the top of the page)
Good morning
I edited my post
October 4, 2019 - 6:56 PM
Run `wapt-scanpackages /var/www/wapt -ldebug`.
Remove the problematic Wapt package, then run
Robin
October 7, 2019 - 9:49 AM
sfonteneau wrote: ↑Oct 4, 2019 - 6:56 PM Run `wapt-scanpackages /var/www/wapt -ldebug`.
Delete the problematic wapt package, then run
Thanks for your reply. It was just a test image at first, so I reverted to my original one. I'll test it next time.
Robin
October 7, 2019 - 10:44
I imported a package and I'm getting the error message again. When you talk about deleting the package, can you tell me which folder on the server it's installed in by default?.
October 7, 2019 - 11:15
Hello, in /var/www/wapt or /var/www/html/wapt,
can you tell me which package you are trying to import?
Robin
October 7, 2019 - 11:31
sfonteneau wrote: ↑Oct 7, 2019 - 11:15 AM Hello, in /var/www/wapt or /var/www/html/wapt,
I wanted to create a simple MSI package (https://www.wapt.fr/fr/doc/wapt-create- ... index.html)
When making my selection, I used "Create and edit..." instead of "Create and upload". Nothing happened, and I've been getting the error message "BadZipFile: File is not a zip file"
I don't have a /var/www/html/wapt directory, and my .msi file isn't in /var/www/wapt
October 7, 2019 - 12:00
Robin wrote: ↑Oct 7, 2019 - 11:31 When making my selection, I used "Create and edit..." instead of "Create and upload". Nothing happened, and since then I've been getting the error message "BadZipFile: File is not a zip file".
Have you installed PyScripter correctly? (If you haven't clicked "build-upload" yet, the server hasn't received anything.)
Robin wrote: ↑Oct 7, 2019 - 11:31 AM I don't have a /var/www/html/wapt directory. And in /var/www/wapt I don't have my .msi file.
First line:
A WAPT package is a zip file that contains several elements
Therefore, you will only find .wapt files in the /var/www/wapt folder
Robin
October 7, 2019 - 2:26 PM
sfonteneau wrote: ↑Oct 7, 2019 - 12:00 PMDid you install PyScripter correctly? (If you haven't clicked "build-upload" yet, the server hasn't received anything.)
I installed it manually. I didn't do it via a Wapt package (I only saw that in the documentation later). So when I try to install it, it doesn't automatically open PyScripter.
sfonteneau wrote: ↑Oct 7, 2019 - 12:00 PM https://www.wapt.fr/fr/doc/wapt-create- ... index.html
First line:
A WAPT package is a zip file containing several elements.
Therefore, you will only find .wapt files in the /var/www/wapt folder.
Yes, I made a mistake with "generate a package template" for the .msi file
