I changed my WAPT password in the console and since then I haven't been able to log in.
Is there any way to change the lost password?
Or am I going to have to delete everything and reinstall?
Thank you.
WAPT Community Edition 1.7.3.5 on Windows 2012 R2
[SOLVED] Lost WAPT password
- WAPT Expert
- WAPT Expert
Hello Beryl,
You retrieve the salted hash and replace it in the file c:\wapt\conf\waptserver.ini
As Simon mentioned, during the upgrade, the installer offers to change your password. Alternatively, a short line of Python code should do the trick (retrieved from postconf.py):beryl wrote: ↑Oct 4, 2019 - 4:41 PM Hello,
I changed my WAPT password in the console and since then I haven't been able to log back in.
Thank you.
c:\wapt\waptpython.exe -c "from passlib.hash import pbkdf2_sha256 ; print(pbkdf2_sha256.hash('mon_super_mot_de_passe'.encode('utf8')))"
