Management problem - Order fails to launch
slena
Registration: Oct 16, 2019 - 1:10 p.m.
November 18, 2019 - 3:19 PM
Following a fresh installation of WAPT 1.7.4 on Debian Buster, I'm trying to run commands on my agents.
The actions (installations, package removal, etc.) don't work while the machine is running. The
logs only show "Downloading XXXXXX-XXX-XXX--XXX" and that's all.
However, after shutting down the machine, the updates/installations complete correctly.
Do you have any idea what the problem might be?
Thank you.
November 18, 2019 - 8:52 PM
Two possible problems:
Signature problem? If you've mixed up the keys
Or perhaps there's a time issue on the PCs (console or agent)
To test the time on both PCs:
C:\Windows\System32>waptpython
Python 2.7.15 (v2.7.15:ca079a3ea3, Apr 30 2018, 16:22:17) [MSC v.1500 32 bit (Intel)] on win32
>>> import datetime
>>> datetime.datetime.utcnow()
datetime.datetime(2019, 11, 18, 19, 49, 14, 894000)
