I have a large number of workstations showing an error in my console because a package failed to install on the computers (Adobe Reader... an Adobe product).
I removed it from the list of packages on my workstations, but the error persists. In the console, half of the workstations are still showing an error.
How can I ask the client to permanently remove this package?
Is it possible from the console? (I can't seem to do it.)
Better yet, what command should I run on the workstations?
Thank you.
[SOLVED] Asking workstations to forget a package that failed to install
- WAPT Expert
Hello JeanPierre1933,
If the machines are powered on, you can select all of them, then in the list of packages on the right, right-click on the package you want to forget and choose "forget". Otherwise, you can create a configuration package using the command line WAPT.forget('mypackage').jeanpierre1933 wrote: ↑Nov 29, 2019 - 11:01 AM I have a large number of workstations showing an error in my console because a package failed to install on the computers. (Adobe Reader... an Adobe product)
So I removed it from the list of packages on my workstations. But the error remains. In the console, I still have half of the workstations showing an error.
How can I ask the client to permanently forget about this package?
Is it possible from the console? (I can't figure it out)
jeanpierre1933
- Registration: Nov 29, 2019 - 10:56
Thank you
, do you have an example of such a package?
If not, what command would need to be executed in the Windows command line?
- WAPT Expert
If the radios are switched on, the simplest solution remains multi-selection.
something likejeanpierre1933 wrote: ↑Dec 5, 2019 - 8:08 AM Thank you
If not, what command would I need to execute in the Windows command line?
WAPT.forget('tis-monpaquet')
