[SOLVED] Asking workstations to forget a package that failed to install
jeanpierre1933
Registration: Nov 29, 2019 - 10:56
November 29, 2019 - 11:01
I have a large number of workstations showing an error in my console because a package failed to install on the computers (Adobe Reader... an Adobe product).
I removed it from the list of packages on my workstations, but the error persists. In the console, half of the workstations are still showing an error.
How can I ask the client to permanently remove this package?
Is it possible from the console? (I can't seem to do it.)
Better yet, what command should I run on the workstations?
Thank you.
December 3, 2019 - 2:25 PM
Hello JeanPierre1933,
jeanpierre1933 wrote: ↑Nov 29, 2019 - 11:01 AM I have a large number of workstations showing an error in my console because a package failed to install on the computers. (Adobe Reader... an Adobe product)
So I removed it from the list of packages on my workstations. But the error remains. In the console, I still have half of the workstations showing an error.
How can I ask the client to permanently forget about this package?
Is it possible from the console? (I can't figure it out)
If the machines are powered on, you can select all of them, then in the list of packages on the right, right-click on the package you want to forget and choose "forget". Otherwise, you can create a configuration package using the command line WAPT.forget('mypackage').
jeanpierre1933
December 5, 2019 - 8:08 AM
Thank you
, do you have an example of such a package?
If not, what command would need to be executed in the Windows command line?
December 5, 2019 - 4:25 PM
jeanpierre1933 wrote: ↑Dec 5, 2019 - 8:08 AM Thank you
If not, what command would I need to execute in the Windows command line?
something like
    WAPT.forget('tis-monpaquet')
If the radios are switched on, the simplest solution remains multi-selection.
