[SOLVED] wapt version 1.8.0.6641 windows package problem
aypierre
Registration: January 24, 2020 - 3:30 PM
January 24, 2020 - 4:05 PM
Hello, I'm starting out with the tool and, following the prerequisites, I retrieved the famous wapt-dev package from my private repository.
When I add it to a machine by selecting "Modify machine," I add the package on the left and save.
Then nothing happens. When I check for updates, nothing changes, and I can't install the package.
I'm looking for a kind soul who could help me...
Server OS (Windows): Windows 10
Administration/Package Creation Machine OS (Windows 10)
kguerineau
Registration: March 6, 2018 - 4:28 PM
January 24, 2020 - 5:46 PM
* Is the PC you want to access set to the correct time?
* Is there a public certificate in the folder C:\Program Files (x86)\wapt\ssl?
* If so, does it correspond to the private key used in the console?
Regards
aypierre
January 27, 2020 - 10:01
* Is the PC you want to work on set to the correct time? Yes
* Is there a public certificate in the folder C:\Program Files (x86)\wapt\ssl? Yes
* If so, does it match the private key used in the console? Yes,
and it still doesn't work... I don't know what to do.
I should mention that my installation is brand new and I've configured everything according to the documentation, but nothing installs...
When refreshing after checking for updates, the status remains green and OK.
aypierre
January 27, 2020 - 10:56
I found the errors in the logs, I managed to fix them, thank you
