[RESOLVED] The wapt configuration remains on version 1.7.4.x after upgrading to 1.8.0
Empbilly
Registration: January 15, 2018 - 8:59 PM
January 24, 2020 - 3:44 PM
My WAPT page shows:
WAPT Server Version: 1.8.0,
WAPT Agent Version: 1.7.4.6077,
WAPT Installer Version: 1.8.0.6641,
WAPT Deploy Version: 1.8.0.6641,
Database Status: OK (1.7.6.6),
Disk Space: 26% Free.
However, when I download the WAPT configuration file, it still shows version 1.7.4.x. The WAPT agent is also still showing version 1.7.4.x.
Is this a bug?
kguerineau
Registration: March 6, 2018 - 4:28 PM
January 24, 2020 - 4:37 PM
To update the WAPT agent, you need to:
* Download the WAPTSetup (https://www.wapt.fr/fr/doc/wapt-configu ... pt-console)
* Generate a new agent (https://www.wapt.fr/fr/doc/wapt-configu ... wapt-agent).
This will change the WAPT agent version on your server to 1.8.0.x
Empbilly
January 25, 2020 - 4:06 AM
kguerineau wrote: ↑January 24, 2020 - 4:37 PM Hello,
Hello, did you give me the link to install the WAPT configuration, because you have the download link or for me to follow the instructions? If you follow the instructions, I've already done so.
- I upgraded to version 1.8
- I open the page wapt.mycompany.com and download the wapt configuration.
- Upon installation, it shows that it is version 1.7.4.x
The Wapt installer is not updating to version 1.8
This is what's happening.
kguerineau
January 27, 2020 - 11:10
if WAPTSetup is still version 1.7.4, clear your browser cache and then restart the download. This should resolve the issue.
Empbilly
January 27, 2020 - 6:45 PM
Thanks kguerineau!! Works!!!
corriou
Registration: May 16, 2019 - 09:59
February 6, 2020 - 4:56 PM
Same problem, same solution.
And since it's not something we tend to think of, it might be worth suggesting in the documentation.
Thanks again.
