[RESOLVED] Updated dependency in the tis-stellarium package
Max
Registration: December 5, 2019 - 11:07
February 20, 2020 - 10:08 AM
I just wanted to point out that the tis-stellarium package has a dependency on tis-vc2013redist, which no longer exists and has been replaced by tis-vcredist2013.
I also just discovered the fantastic tis-vcredist-all package, which is incredibly useful!
Is it possible that the new packages conflict with the old ones and need to be removed? The problem seems to be related to the naming convention: tis-vc20XXredist refers to the old package and tis-vcredist20XX to the new one.
Otherwise, thank you for everything!
Have a good day.
February 20, 2020 - 10:22
Hi Max,
You can edit the package with PyScripter and modify the control file to change the dependency.
I've added an internal issue to fix this package on the store.
Thanks for reporting the error.
Best regards,
Max
February 20, 2020 - 1:18 PM
With pleasure!
You'll have the naming issue vcredist20XX / vc20XXredist with tis-tortoisesvn, tis-bluegriffon, and tis-camstudio.
See you soon!
Maxime
