Do you have a solution to force the installation of https://yourwaptip/wapt-host/clientPCname.wapt ?
I have the impression that it's stuck at this point.
HTTP 404 error, wapt package update
- WAPT Expert
Before looking at the host package,
does `wapt-get install test-audacity` work?
- WAPT Expert
Works perfectly for me on Windows 10
However, I had to enable the following in the GPOs:
Computer Configuration\Administrative Templates\System\Logon\Run shutdown scripts visible = Enable
You can also activate it via a registry key: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System]
"HideShutdownScripts"=dword:00000000
"VerboseStatus"=dword:00000001
For your host package:
In the wapt-get.ini file, you should have:
And the machine name package present in: http://wapt/wapt-host/mamachine.wapt
use_hostpackages = 1And the machine name package present in: http://wapt/wapt-host/mamachine.wapt
