I'm revisiting this topic: viewtopic.php?f=10&t=2226&p=7240&hilit=certificat#p7240 because I have the same problem. The "Save and Apply" and "Save" buttons in "Edit Machine" are grayed out.
Your documentation is very well written \(^0^)/ but I haven't found an answer there /(- _ -)\.
WAPT version: 1.8.1.6756 (Community)
Server OS: Windows Server 2012 R2
Client OS: Windows 7
I installed the waptagent with waptdeploy via a GPO.
Communication between the waptagent and the WAPT server is established.
The client and server clocks are synchronized.
I can download packages from the internet.
I think the problem lies with the certificate. Indeed, I have a certificate located in C:\private but not in C:\wapt\ssl.
So I copied and pasted it there, but it didn't solve anything.
Best regards.
[SOLVED] Unable to edit a machine
- WAPT Expert
the button only activates if you have a certificate entered in the console:
Tools -> Preferences -> Personal Certificate Path.
same certificate must also be recognized by the machine (the certificate must be located in C:\Program Files (x86)\wapt\ssl) on the agents.
If this is not the case, add it and then restart the wapt agent.
thank you for your quick reply!
On the server side, I put the certificate in C:\wapt\ssl and regenerated a WAPT agent. I deployed it to replace the old one, and it works! The certificates are now also in the ssl folder on the client machine.
I can deploy the packages without any problems.
Thanks again, and have a good day!
