Today I'm trying to go a little further by attempting to create a log file during the installation of a package.
I created a quick package with the following code:
import logging
softname = 'Everything 1.4.1.969'
logging.basicConfig(level=logging.DEBUG,filename='%appdata%\everything.log',filemode='w',format='%(asctime)s - %(levelname)s - %(message)s')
print('installing agri-everything')
logging.info("Début de l'installation")
install_exe_if_needed("Everything-1.4.1.969.x64-Setup.exe",'/S',key='',min_version='1.4.1.969')I therefore rely on your experience to ask where I am making a mistake or if there is another way to generate a log file.
Thank you so much.
Patrice
