[SOLVED] Registering a Linux machine
jc35
Registration: Apr 15, 2020 - 4:17 p.m.
April 15, 2020 - 4:29 PM
Hello everyone,
how can I register a Linux machine without it asking for a password?
I tried `wapt-get -m`, but it didn't give me any information about it.
The `host_organizational_unit_dn="` field in `wapt-get.ini` isn't being used either.
April 15, 2020 - 5:50 PM
For registration
wapt-get register --wapt-server-user=admin --wapt-server-passwd=password
host_organizational_unit_dn will be fixed in the next version ;)
jc35
April 16, 2020 - 8:48 AM
Thank you so much.
florentR2
Registration: February 13, 2020 - 5:23 PM
April 16, 2020 - 5:09 PM
sfonteneau wrote: Apr 15, 2020 - 5:50 PM For registration
Would this work on Windows?
I can't find an option so that during agent installation it doesn't perform the "register" operation and then pass it as a parameter as you indicated.
April 16, 2020 - 5:11 PM
Yes, absolutely, it works under Windows too.
Kerberos authentication isn't working for you?
florentR2
April 16, 2020 - 5:14 PM
sfonteneau wrote: Apr 16, 2020 - 5:11 PM Yes, absolutely, it works under Windows too.
Kerberos authentication doesn't work for you?
We're working on it (see another thread) but since we don't have control over our DC while waiting for the modifications, we wanted to test it this way.
April 16, 2020 - 5:20 PM
For your information, Kerberos authentication will also be possible for Linux and Mac workstations
