Operand type problem on remove_desktop_shortcut
jlatieule
Registration: July 3, 2019 - 9:18 AM
April 21, 2020 - 10:49
I am looking to automate the deletion of a shortcut by retrieving the name of the software present in the control file.
    nom_salvia = control.description.split(' ', )[-1]
    print nom_salvia
    # Suppression raccourci bureau public
    remove_desktop_shortcut('%s') % nom_salvia
I received the following error message
2020-04-21 10:45:00,736 CRITICAL Fatal error in uninstall function: TypeError: unsupported operand type(s) for %: 'NoneType' and 'unicode':
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2316, in call_setup_hook
hookdata = hook_func()
File "c:\waptdev\ophlm-salvia-financements-wapt\setup.py", line 44, in uninstall
remove_desktop_shortcut('%s') % salvia_name
I tried different methods, all of which turned out to be wrong.
How can this problem be solved?
Thank you in advance
Sincerely
System and Network Administrator at Domitia Habitat
April 21, 2020 - 5:58 PM
I'm opening a ticket with us because there is indeed a problem when using the "description" of the control object in uninstall.
The value is None.
jlatieule
April 30, 2020 - 10:55 AM
It works, now we just have to wait for the fix.
Thanks again.
