[SOLVED] Triggering Waptexit at a specific time
Malo
Registration: March 30, 2020 - 11:02
April 21, 2020 - 11:12
I'm using Wapt v1.8 on Windows Server 2016 (console) and Windows 10 (client).
I'd like to know if it's possible to trigger Waptexit (automatically) at a specific time of day.
If so:
- How do I do this?
- What will happen if an application that needs updating is open at that time? Will it be forced to close and any unsaved data lost? What does the Wapt console return?
Thank you in advance. :)
April 21, 2020 - 5:35 PM
Good morning
You can run the `wapt-get upgrade -S` command automatically during the day using a scheduled task
If the applications are launched... they will be killed
If you are using the enterprise version, you can also regularly offer the update to users using scheduled tasks:
waptpython -c "from waptenterprise.waptservice.enterprise import start_waptexit ; start_waptexit('task',{'only_priorities':False,'only_if_not_process_running':True,'install_wua_updates':False,'countdown':300},'schtask')"
