Clean up the database on the Wapt server (version 1.8.1)
ryoken95
June 2, 2020 - 2:54 PM
Our IT infrastructure has changed significantly, and we would like to know the best method to "clean" the list of workstations in order to start from scratch.
Our goal is to have a list of PCs with no packages installed.
Our configuration:
WAPT Server version: 1.8.1 Debian 9;
WAPT Agent version: 1.8.1.6756 (Windows 10 and 7).
Could you please tell us the procedure?
Regards
June 9, 2020 - 9:40 AM
If you select all the machines in the interface and check both "remove machine from inventory" and "remove configuration package," that should clean everything up. However, the machines will still have their local agent with their package database and will send back the same data as soon as they have the opportunity to connect...
Regards,
