I'm an intern at a company and my task is to install and configure WAPT in order to deploy software to new workstations.
I'm stuck on installing the tis-waptdev package. Should I install it from the local repository on my admin console and then install it on the server using WAPT?
I'm using Windows 10 VMs. My WAPT version is 1.8.1.
[SOLVED] Installing tis-waptdev
- WAPT Expert
You need to import waptdev into your repository and then install it on the development machine.
