I'm following up on my first post: viewtopic.php?f=9&t=2389 , regarding creating a printer.
The script suggested by sfonteneau works. However, there's no configuration, and my driver, by default, chooses an unbelievable format (8.5 x 11").
So I wanted to configure it, but these settings aren't readily available (or I'm just not good at searching). I did manage to find a solution by exporting and then importing a configuration using the command:
- RUNDLL32.EXE PRINTUI.DLL,PrintUIEntry /Ss /n "Schumann copier 5th floor" /a C:\A4-format.dat
- RUNDLL32.EXE PRINTUI.DLL,PrintUIEntry /Sr /n "Schumann copier 5th floor" /a C:\A4-format.dat
Edit: Note: Of course, I only perform the export once, on a machine that's already configured, to get the basic configuration. Then I try to reproduce the import with /Sr using a package. wapt.
However, the command only works during import when we have an absolute path. The test below leads me to this conclusion:
When I'm in my command prompt at c:> and I type the option /a 'A4-format.dat', the operation fails and stops, but with /a 'C:/A4-format.dat' it works, and when checking the printer properties, the format has indeed changed. The result is the same whether the command prompt window is launched as administrator or not.
My question is:
- Have I misunderstood something in the execution of printui.exe? Do you have any documentation on how to directly assign the printer settings, rather than relying on a configuration file?
- If I understand correctly, what solution should I recommend?
- There is a folder on the client computer, for each wapt package, which could be pointed to with an absolute path that would therefore not change for each Workstation?
- Should we use a network share to store the source files?
- Another solution? (Use a command to copy the .dat source file to the client workstations, for example to c:/source_wapt/fichier.dat, then set the new absolute path, thus avoiding a general configuration, but using a general script.)
[SOLVED] Package with absolute path requirement.
- WAPT Expert
The package is unzipped into a temporary directory with a random name. You can retrieve the path to the directory where it is unzipped using the `basedir` variable.
Thanks, the basedir variable is great.
However, ultimately, that doesn't seem to be the main problem.
In my script, which I largely borrowed from sfonteneau for the printer creation, here are the two active lines:
- Installed the "Schumann Copier 5th floor" printer. Works without any problems.
run(ur'rundll32 printui.dll,PrintUIEntry /if /b "%s" /f %s /r "IP_%s" /m "%s" ' % (nameprinter,path_driver,portprint,name_drivers))
- Supposed to import the "printer-format.dat" printer settings into the Schumann copier/printer. Does not work from PyScripter.
run(u'printui.exe /Sr /n "Schumann copier 5th floor" /a /f %s\printer-format.dat' %(basedir))
So I tried a /f which changed nothing, and added the full path with basedir. Nothing changed.
However, as a reminder, there are no problems using CMD directly, with the same files and the same paths. Or rather, not quite:
When I build the package and push it to my local repository, then try to modify it, and run a command to the printer-format.dat file, it says "unable to complete the operation" (for the import). So I export to overwrite the file, and import it again, and then it works.
I have a feeling this might be related to a Windows security issue. I've encountered many errors like this while creating my packages. Sometimes I find workarounds that seem more like hacks (using batch files or PowerShell) than legitimate fixes.
In short, I'm going in circles and don't understand the error codes being returned. Do you have any tips for improving my understanding of them?
For your information, here is my install function:
Here is the error code when I run an "install" command in PyScripter:
Not knowing which information might be truly important to you, feel free to ask me questions if needed. I already post a lot, and I wouldn't want to discourage people who might have wanted to read my posts.
if iswin64():
path_driver = r"IT5DSETWin_10110FR\Drivers\PCL6\Win_x64\KOAXTJ__.INF"
name_drivers = "KONICA MINOLTA C287SeriesPCL"
path_driver = r"IT5DSETWin_10110FR\Drivers\PCL6\Win_x86\KOAXTJ__.inf"
# Delete old printer
run_notfatal('rundll32 printui.dll,PrintUIEntry /n "%s" /dl /q ' % nameprinter)
# Create port lpr or raw
createprinterport_raw(portprint)
# use create lpr if needed
#createprinterport_lpr(portprint,'qu')
# Install printer and drivers
run(u'printui.exe /Sr /n "Copieur schumann 5eme etage" /a /f %s\printer-format.dat' %(basedir))Code: Select all
2020-06-11 10:51:51,466 CRITICAL Fatal error in install script: CalledProcessErrorOutput: Command 'printui.exe /Sr /n "Copieur schumann 5eme etage" /a /f c:\\waptdev\\wapt_av-5thFloor-printer-wapt\\printer-format.dat' returned non-zero exit status 1.
Output::
File "C:\Program Files (x86)\wapt\common.py", line 3800, in install_wapt
File "c:\waptdev\wapt_av-5thFloor-printer-wapt\setup.py", line 36, in install
File "C:\Program Files (x86)\wapt\common.py", line 3570, in run
return ensure_unicode(setuphelpers.run(*arg,**args))
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3863, in run
Output:
FATAL ERROR : CalledProcessErrorOutput: Command 'printui.exe /Sr /n "Copieur schumann 5eme etage" /a /f c:\\waptdev\\wapt_av-5thFloor-printer-wapt\\printer-format.dat' returned non-zero exit status 1.
Output:
Exit code: 3- sfonteneau
- WAPT Expert
for the order
Perhaps it needs to be run in user context? with session-setup
run(ur'printui.exe /Sr /n "Copieur schumann 5eme etage" /a /f %s\printer-format.dat' %(basedir))
The session-setup is useful! It just goes to show I'll need to check out a bit more of everything wapt can do for me.
In this case, it was related, but not directly. It's the printui executable that directly sets the context; we can modify it with flags at the end of the imported configuration file. So here's the new line that works in user context and executes correctly from "def install:"
And actually, to go further, I was going to run into a problem: my import wouldn't contain any formatted data, because you need flags to specify what you want to export. So you have to export with:
And import with:
What is important is to export and import with the "u" to use the same context.
Here is the topic that helped me:
https://stackoverflow.com/questions/173 ... ompleted-e
run(ur'printui.exe /Sr /n "Copieur schumann 5eme etage" /a %s\printer-format.dat u' %(basedir))Code: Select all
Rundll32.exe printui.dll,PrintUIEntry /Ss /n "Copieur Schumann 5eme etage" /a printer-format.dat c m uCode: Select all
run(ur'Rundll32.exe printui.dll,PrintUIEntry /Sr /n "Copieur Schumann 5eme etage" /a %s\printer-format.dat c m p r u' %(basedir))Here is the topic that helped me:
- WAPT Expert
Thank you so much! Very helpful!
Thank you for the code for deploying and configuring the printers.
The deployment works fine, but in Pyscripter when I launch the installation to test, the printer settings only work for my domain admin account (ads samba domain).
However, if I manually run the following command line in the user's session using cmd
The configuration applies correctly for my user.
Could I have missed a setting that causes the printer deployment to work but not the configuration for users?
Thank you for your feedback
RUNDLL32 PRINTUI.DLL,PrintUIEntry /Sr /n "Copieur Administratif Etage" /a C:\waptdev\tis-install-printer-Administratif_Etage-wapt\disk1\config-CAE.dat uCould I have missed a setting that causes the printer deployment to work but not the configuration for users?
