I recently installed WAPT on CentOS 7 (I'm new to WAPT).
The console works fine, as do the client machines where waptagent.exe is installed.
I generated the WAPT agent from the console.
Today, I received the following notification when I started my console:
"waptagent.exe needs to be updated.
Current version of waptagent.exe: 1.8.1.6756.
Required version: 1.8.2.7265.
Do you want to rebuild a waptagent.exe installer now?"
I recreated the WAPT agent, as suggested when the console started.
However, I can see from the console that the version of "org"-waptupgrade is still at 1.8.1.6756-26 in the Private Repository tab.
What does the notification mean when the console starts? And what do I need to do to update waptagent to 1.8.2.7265?
Best regards,
Ed
[RESOLVED] waptagent 1.8.2
- WAPT Expert
you need to go to the WAPT server's web interface, download and install waptsetup-tis.exe.
Then you will be able to restart the generation of a WAPT agent.
