Answer file
jojo456
Registration: June 4, 2020 - 4:22 PM
June 16, 2020 - 11:52
I'd like to install software using license keys and, to do this, I need to create answer files to include in the packages.
I'm completely unfamiliar with this process, and my research hasn't been very helpful.
What is the structure of an answer file? What is its extension? And once it's created, do I just use "filecopyto" in my setup.py file?
Thanks in advance.
June 17, 2020 - 11:14 PM
It's difficult to say without having the corresponding software... The answer files depend on the packager used (msi, installshield, innosetup, nsis, etc.) and it doesn't always work.
