I have the same problem as in this post, except I have an up-to-date version.
I'm having trouble updating packages imported from the internet to the tranquil.it repository. Each time I import, I get a message about a corrupted package due to an MD5 checksum error. I've cleared the local cache without success.
Do you have any suggestions for resolving this issue?
WAPT server 1.8.2.7265,
OS Windows Server 2012.
Thanks in advance.
MD5 error during import from the Internet
- WAPT Expert
With all the packages?
- WAPT Expert
Any details about your network configuration? Proxy, firewall, filtering, etc.?
Do you have the same problem if you download one of the packages with your browser?
Does it crash immediately, or does it actually start downloading?
You'll need to update your forum message signature.
- WAPT Expert
I just encountered this problem yesterday.
Could you check if the Tranquil repository URL ends with a slash (/)? If so, you can delete it.
https://wapt.tranquil.it/wapt
sorry for the delay. Just so you know, this happens with all packages and it was definitely caused by the repository I was using, because I didn't have any problems with another repository.
I did remove the slash from the repository address and it works. Has this changed recently, or did someone on my team tamper with the repository address?
WAPT 1.8.2.7265
