I'm setting up a WAPT server and I've ended up with a lot of certificates scattered everywhere...
I have them in:
- c:\wapt\private: a random name with a .crt file and the same one with a .pem file
- c:\wapt\ssl: administrator.crt
- c:\private: administrator.pem and administrator.crt
I don't understand these certificates at all.
Administrator.pem and .cert were created during installation, but the rest...
Could someone please explain the differences and what I should keep/delete?
Thank you in advance.
[RESOLVED] Certificates
- WAPT Expert
in Wapt you can recognize private keys as .pem files and public keys as .crt files.
In C:\private you have your private and public key pairs which allow you to sign packets (mykey.pem and mykey.crt).
In c:\wapt\ssl you only have mykey.crt, this tells your agent that it accepts all Wapt packets from the mykey.pem key.
As for the files in c:\wapt\private, they are completely internal to Wapt; you don't need them.
For more information, see: https://www.wapt.fr/fr/doc/wapt-securit ... urn-states.
Regarding the certificate, which is potentially located in c:\wapt\wapt\ssl\server, see:
https://www.wapt.fr/fr/doc/wapt-securit ... apt-agents
thank you for the clarification.
I'm facing another issue: package uploading.
When I go to "Tools," then "Generate Package Template," the "Create and Upload" button remains grayed out.
I have to go to "Create and Edit," then go to the PyScripter project explorer and type "-i build-upload."
I saw that I needed to set the prefix and enter the certificate in the WAPT console preferences, but that didn't change anything.
- WAPT Expert
That's normal if it's an executable file, since the package must be tested before upload (using an uninstall key, etc.)
https://www.youtube.com/watch?v=z_EN2CBCTcY
