Send a message (MessageBox) / .reg
AdriAlpes
Registration: July 1, 2020 - 12:19
July 1, 2020 - 12:37
Hello everyone,
I'd like to create a MessageBox in the `def install()` function to inform the user that they must restart their machine after installing the package (registry key declaration in the session setup() function).
However, I'm getting a timeout when I install the package, even though I don't encounter any problems on my own machine.
Here's the code I'm using:
`win32ui.MessageBox('test','test')`
or
`os.system('cmd /c "msg /TIME:1750 %username% test"')`
I tried to work around the problem by writing the key (HKCU) in the `def install()` function, but it doesn't work. Is it possible to install the package as the machine's user account, rather than using the System account, to write the key to the HKCU?
Another inconclusive test: I copied a .reg file to the root of my hard drive and then ran it with this code:
`run(r'REG IMPORT C:\test.reg')`
or
`subprocess.call(['reg', 'import', C:\test.reg])`.
Do you have any idea what the problem might be?
Best regards,
Adrien
vcardon
July 1, 2020 - 2:08 PM
take a look here: https://lists.tranquil.it/pipermail/wap ... 04007.html
Regards,
Vincent
AdriAlpes
July 1, 2020 - 2:13 PM
Hello Vincent,
Thank you for your reply, I'll try that right away.
Have a good afternoon,
Best regards,
Adrien
July 1, 2020 - 2:49 PM
msg /TIME:1750  * test
Alternatively, in Wapt Enterprise:
from waptenterprise.waptservice.enterprise import show_message
show_message(None,{'msg':'Hello !'},'Simon Fonteneau')
AdriAlpes
July 1, 2020 - 4:04 PM
Thank you for your reply. I used "vcardon's" solution, which works, thanks again!
Do you have any ideas for the .reg file? It's a large registry modification with 300 keys to change.
Thank you in advance and have a good afternoon
. Best regards
Adrien
