[SOLVED] Package tis-microsoft-teams
Yoann
Registration: July 24, 2019 - 09:39
September 1, 2020 - 12:24
Several topics have already been posted on this forum regarding the package tis-microsoft-teams suggested in the repository. I preferred to create a new topic to discuss several questions I have.
1) In this package, Microsoft Teams is installed using the MSI file and the argument ALLUSER=1 (without the "S").
This argument is used only in VDI environments.
Therefore, in order to install Teams on a classic (non-VDI) environment, keys (VMware, Citrix) are added to the registry and trick the installer into thinking it is on a VDI environment.
Why was this approach preferred rather than using the MSI with the arguments (OPTIONS="noAutoStart=true" ALLUSERS=1) which work in both VDI and non-VDI environments?
This would also avoid file manipulation setup.json to disable Teams from automatically starting when logging in.
2) In the current package, I may have missed something, but could there be a problem with the function session_setup().
The current version of Teams is retrieved into a variable (user_app_version) from the registry but does not appear to be used subsequently. A condition would be missing:
    if Version(user_app_version) < Version(package_version):
        # Killing app before making changes
        killalltasks('Teams.exe')
THANKS,
Sincerely.
WAPT Community 1.8
jpele
Registration: March 4, 2019 - 12:01
September 1, 2020 - 4:27 PM
1) We made this choice for better management of installations via WAPT and a lighter, "cleaner" PC environment on multi-user workstations.
Look in previous versions; you'll find the package you mentioned with "ALLUSER=1".
2) This variable was used for the previous method; it can indeed be commented out.
Regards,
Jimmy
September 1, 2020 - 4:54 PM
With ALLUSERS=1, MSTeams installs itself in users' AppData folders. This is rather messy and not really compatible with SRP/APPLocker. Tranquil IT's choice was to force installation in Program Files using the method currently employed in the package.
Yoann
September 1, 2020 - 6:20 PM
I understand better now, thank you for these explanations.
WAPT Community 1.8
