I'm creating a package to migrate from Firefox 32-bit to the 64-bit version.
I have no problem removing the 32-bit version and then deploying the 64-bit version using the package from the Tranquil IT repository.
My issue is making the 64-bit version the default browser for ALL users.
Using the DISM and XML method, it only works for new users, not existing ones.
After searching the forum, I tried various methods that didn't work:
`firefox.exe -silent -setDefaultBrowser
C:\Program Files\Mozilla Firefox\
C:\Program Files\Mozilla Firefox\uninstall\helper.exe /SetAsDefaultGlobal` and
`C:\Program Files\Mozilla Firefox\uninstall\helper.exe /SetAsDefaultAppUser`.
you have a reliable method that would work?
Firefox by default when switching from the 32-bit to the 64-bit version
