We're encountering a small problem during installation after creating a package for Inventor Pro 2021.
Here's the general information
: WAPT version installed: Enterprise v 1.8.2.7334
Server OS: Debian Buster
WAPT administration OS: Windows 10 1909
Here are the logs that Python returns when we launch the installation:
File "C:\Program Files (x86)\wapt\common.py", line 3877, in install_wapt
File "C:\WaptDEV\ima-setup-wapt\setup.py", line 7, in install
install_exe_if_needed("Img/Setup.exe",'/qb /I IMASONIC.ini /Trial /language fr-fr',key='Autodesk Revit Interoperability for Inventor 2021',min_version='21.0.0.376')
File "C:\Program Files (x86)\wapt\common.py", line 3831, in new_func
return func(*args,**kwargs)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1172, in install_exe_if_needed
run(r'"%s" %s' % (exe,silentflags),accept_returncodes=accept_returncodes,timeout=timeout,pidlist=pidlist)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3713, in run
killtree(proc.pid)
File "C:\Program Files (x86)\wapt\waptutils.py", line 1576, in killtree
parent.kill()
File "C:\Program Files (x86)\wapt\lib\site-packages\psutil\__init__.py", line 311, in wrapper
return fun(self, *args, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\psutil\__init__.py", line 1120, in kill
self._proc.kill()
File "C:\Program Files (x86)\wapt\lib\site-packages\psutil\_pswindows.py", line 288, in wrapper
raise AccessDenied(self.pid, self._name)
AccessDenied: psutil.AccessDenied (pid=28628)
FATAL ERROR: AccessDenied: psutil.AccessDenied (pid=28628)
Exit code: 3
despite everything, the installation is launched, and above all works. The uninstallation didn't show any issues in the logs.
Thank you in advance for your help!
Olivier MARCOUX
