[SOLVED] Upgrade 1.8 Community -> 1.8 Enterprise
olaplanche
Registration: January 26, 2017 - 11:11
May 12, 2021 - 12:06
I can't find the appropriate procedure in the documentation for what I want to do.
I would like to upgrade to the enterprise version without changing the version number initially.
So I tested it:
Change the repository to the enterprise repository using my credentials, then force a reinstallation of the packages with the command:
apt --reinstall install tis-waptserver tis-waptrepo tis-waptsetup
I restarted the postconf and regenerated the WAPT agent, but when I download the agent setup from my WAPT repository, it's still the community version setup
I must be forgetting something, do you have any idea?
THANKS
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
Gaetan
Registration: August 8, 2019 - 10:16
May 12, 2021 - 12:15
did you do a remove and then an install rather than a reinstall?
Was an update performed correctly?
olaplanche
May 12, 2021 - 2:23 PM
Okay, after checking the /etc/apt/sources.list.d/wapt.list file, the repository update command didn't work. :roll:
It works much better with the correct repository configured now. :mrgreen:
Sorry for the inconvenience. :lol:
Gaetan
May 12, 2021 - 2:32 PM
:D
Great ;)
