[SOLVED] Problem between Pyscripter 4 and the Python engine
olaplanche
Registration: January 26, 2017 - 11:11
May 17, 2021 - 2:05 PM
since updating PyScripter to v4, it can no longer find the Python path in the Wapt installation folder. See the screenshot below:
Do you have any suggestions?
Thank you
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
May 17, 2021 - 2:45 PM
32-bit PyScripter? (Wapt is 32-bit, so it needs 32-bit PyScripter, not 64-bit)
olaplanche
May 17, 2021 - 3:43 PM
yes version 4.0.0.5 x86, I used the pyscripter package from the wapt store.
May 17, 2021 - 3:55 PM
The package has a problem; it's installing the x64 version. :roll:
I'll look into it.
olaplanche
May 17, 2021 - 3:59 PM
Ah, that's reassuring. :mrgreen:
I'll wait for your reply to do the update.
Thanks.
jpele
Registration: March 4, 2019 - 12:01
May 17, 2021 - 6:13 PM
I've tested again on several environments and the PyScripter package installs correctly on x86.
Could you completely remove PyScripter and install it from the package, then test again?
Regards,
Jimmy
olaplanche
May 18, 2021 - 11:29
I'm having the same problem after reinstalling v4, and the same after reinstalling v3 (and removing v4 from my local store).
v4 is no longer available on the Wapt store, so I can't reinstall it from there.
Thanks
olaplanche
May 19, 2021 - 2:14 PM
OK, I just solved my problem!
After analyzing the pyscripter v3 package (v4 is "broken") available on the store, it seems that the modifications made to the pyscripter.local.ini file are not taken into account during installation (at least not on my system).
I copied the following Python version modifications to the end of the pyscripter.local.ini file in my machine's local administrator profile:
[PythonVersions-x86]
InstallPath=C:\Program Files (x86)\wapt
[PythonVersions-x86\Custom Versions]
Path0=C:\Program Files (x86)\wapt
Count=0
After this modification, pyscripter is working properly again (I just updated a package)
olaplanche
May 19, 2021 - 2:23 PM
After using PyScripter, the pyscripter.local.ini file changed as shown below:
Path0=Python 2.7 (32bit)=C:\Program Files (x86)\wapt
Count=1
May 20, 2021 - 09:47
Actually, it's quite simple:
pyscripter4 is no longer compatible with Python 2.7.
Therefore, you'll have to wait for the discovery to use pyscripter4.
