Hello!
I'd like to know if anyone in the community has already developed an Office 2013 with license management and could share it with me, or help me develop my own, as I'm not sure how to do it.
The few tutorials I've found here are a bit outdated or incomplete.
Sincerely.
[RESOLVED] Office 2013 package with license management
If you are using a KMS volume license, you need to generate an XML file and pass it as a parameter with /config during installation.
For example, our XML looks like this:
And the setup.py
<Configuration Product="ProPlus">
<Display Level="basic" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" NoCancel="no" />
<Setting Id="KMSSERVICENAME" Value="ServeurKMS.xxx" />
<Setting Id="AUTO_ACTIVATE" Value="1" />
</Configuration>Code: Select all
install_exe_if_needed("setup.exe",'/adminfile officeproplus2013_32bits.msp /config config.xml',key='Office15.PROPLUS',min_version='15.0.4420.1017', timeout=1800)
For the This is the standard Office deployment method. You should consult the Microsoft documentation.
For the WAPT uses it to check if the software is properly installed; it also prevents Office from reinstalling if it's already installed. You can obtain it with
/adminfile officeproplus2013_32bits.mspFor the
key='Office15.PROPLUSCode: Select all
wapt-get list-registry office
