product information request
Share your experience and thoughts about WAPT here / Come here and talk about your experience with Wapt, your opinion and your wishes
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
ptiseb
Registration: February 29, 2016 - 5:04 PM
February 29, 2016 - 5:10 PM
Hello everyone,
I was looking for a solution to deploy Java and Acrobat Reader updates when I came across this product, which seems to address almost all my needs. However, I can't find any information on deployment scheduling options, so I'm turning to the forum...
Is it possible to schedule deployments, and more importantly, how does it behave when remote machines are unreachable at the time of deployment in the case of a scheduled deployment?
Another question: what ports are used? I have a restriction on inter-VLAN communication.
Thank you in advance for your answers.
February 29, 2016 - 6:45 PM
Deployment planning:
1- On shutdown via a local GPO (waptexit process)
2- On startup via a GPO or login script (run wapt-get upgrade)
3- By voluntary user action (via an icon in the notification area or a shortcut on the desktop/start menu)
4- By remote triggering by the administrator via the WAPT console if the machine is reachable
5- By scheduling a Windows task...
Ports used:
- HTTP protocol 80 / HTTPS 443 required: clients to WAPT repositories
- HTTPS protocol 443: clients to the WAPT server to retrieve the inventory/status of deployments
- Optional: HTTP or HTTPS protocol on port 8088 by default (other ports possible...) from the WAPT server to clients if you want to trigger updates from the WAPT console.
Floflobel
Registration: Oct 15, 2015 - 5:32 p.m.
March 1, 2016 - 10:44
is it possible to do this randomly?
This would avoid network overload.
