Execute a package at each machine restart
tuxmania
Registration: Sep 22, 2020 - 4:48 p.m.
July 15, 2021 - 10:44
is it possible to make a package run every time WAPT starts?
I have a package that needs to run once a day (like a scheduled task), but without having to increment the package version every day!
Is there a way to do this?
Thanks in advance.
July 15, 2021 - 9:29 PM
See the forum rules above.
You could create a scheduled task that performs a force install at each startup. That said, we would need a little more information to give a more informed opinion.
Regards,
tuxmania
July 16, 2021 - 09:38
Hello Denis,
thank you for your reply.
Here's some more information:
Wapt agent version: 1.8.2,
OS: Windows 10.
To elaborate on my request, I have a Python script that retrieves the timezone from the internet based on the user's geographical location (using the IP address). From there, the script applies the correct timezone to the PC by modifying the settings in Windows.
The idea of ​​forcing the script to execute every time Wapt is launched would allow (for people who travel to different timezones) for automatic timezone adjustment.
My goal was to use only Python and not batch scripts or PowerShell.
Thank you in advance.
florentR2
Registration: February 13, 2020 - 5:23 PM
July 16, 2021 - 12:06 PM
Scheduling an audit every X hours should do the trick.
However, it won't necessarily run when the PC starts up.
tuxmania
July 16, 2021 - 7:00 PM
Hi florentR2,
thanks for the feedback.
I added the "audit_schedule" attribute to the control file with a value of "1m" but nothing happens.
Do I need to add an "audit" function to setup.py or make another modification?
Thanks in advance.
florentR2
July 19, 2021 - 08:59
Yes, you need an audit() function
def audit():
    # put here code to check periodically that state is matching expectations
    # return "OK", "WARNING" or "ERROR" to report status in console.
    # all print statement are reported too
    return "OK"
tuxmania
July 19, 2021 - 11:18
Hello florentR2,
thank you very much for your feedback.
I will do it that way.
Have a good day.
