Hello, is there a way to perform a speed test (network connection performance for sending and receiving at a given time) on Windows workstations via a WAPT package deployment (it probably already exists, but I haven't found it)? Thank you in advance, best regards.
(Windows workstations are running version 2.0.0 / WAPT Enterprise version on a Debian Buster server / admin console on Windows 10)
Speedtest
- WAPT Expert
Hello Thomas789,
is the goal to validate the data transfer rate between the agent and the WAPT server, or the download speed more generally?
- WAPT Expert
If you have the correct command line, you can create a package with the binary and call it in the `install` function (run only the first time), or in `def audit()` (for frequency management, refer to the documentation). The printouts will be sent back to the server.
