I installed the updates yesterday but it didn't change anything.
Regards
[RESOLVED] WAPT enterprise - external repository error
for those who might have the same problem, this is a bug in version 2.0 that should be fixed in version 2.1 (see support).
The waptconsole.ini configuration file is not being written with the correct parameters from the console. It must therefore be modified manually with the console closed for the settings to take effect the next time the application is launched.
In my case, it was the proxy settings.
Problem solved by support!
Thank you to them.
Regards
Thank you to them.
Regards
