[SOLVED] Microsoft Office Pro 2016 Package
olaplanche
Registration: January 26, 2017 - 11:11
October 8, 2021 - 4:01 PM
I'm sharing my Office Pro 2016 package.
Prerequisites:
Run the command "setup.exe /admin" to generate an MSP file to save in the updates folder of the setup folder containing all the installation files. The setup folder must be copied into the package.
uninstallkey = ['Office16.PROPLUS']
    print('installing wapt-office2016pro')
    install_exe_if_needed("%s\setup\setup.exe" % basedir,silentflags='',key='Office16.PROPLUS',min_version='16.0.4266.1001',timeout=1200)
    uninstallkey.remove('Office16.PROPLUS')
    print('uninstalling wapt-office2016pro')
    import tempfile
    pathuninstallfile = makepath(tempfile.gettempdir(),'SilentUninstall.xml')
    data = r"""<Configuration Product="ProPlus"><Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" /></Configuration>"""
    fichier = open(pathuninstallfile, "w")
    fichier.write(data)
    fichier.close()
    run(r'"%s\Common Files\Microsoft Shared\OFFICE16\Office Setup Controller\setup.exe" /uninstall ProPlus /config %s' % (programfiles32,pathuninstallfile))
    remove_file(pathuninstallfile)
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
October 14, 2021 - 3:01 PM
Thanks for sharing, olaplanche!
olaplanche
October 28, 2021 - 11:50
My pleasure.
Code modified to be compatible with Python 3:
The line:
data = ur"""<Configuration Product="ProPlus"><Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" /></Configuration>"""
becomes :
