Console problem (Add: Unexpected array item in an object)
thomas789
Registration: May 31, 2021 - 3:44 p.m.
December 10, 2021 - 3:08 PM
(Windows workstation agents on version 2.1.1 / WAPT Enterprise version on a Debian Buster server / admin console 2.1.1 on Windows 10)
I'm encountering the following error popup: "Add: Unexpected array item in an object", when I try to edit a package from the Private Repository tab in the console.
Thank you in advance, best regards.
December 11, 2021 - 10:30 AM
I recently encountered this problem with a client who still had old packages that didn't have a package_uuid (a column visible in the private repository).
This caused the console to crash.
Could you check this?
thomas789
December 14, 2021 - 11:11
No, I just checked and all our packages have a UUID.
Regards, Thomas.
thomas789
January 10, 2022 - 09:14
Up please :)
thomas789
February 9, 2022 - 10:46
Hello, the problem is solved after upgrading to WAPT server version 2.1.2.
