[RESOLVED] Meshcentral
infocfd
Registration: Apr 11, 2018 - 4:18 p.m.
April 4, 2022 - 3:56 PM
a Wapt server 1.2.1 enterprise
OS Linux server
administration machine running Windows 10.
We use MeshCentral on our workstations, which we deployed from Wapt, but how can we integrate it with the Wapt console and access our machines from the console?
Thank you in advance.
April 11, 2022 - 2:05 PM
Hello infocfd,
in order for the console to access the mesh server, it needs information from the workstation (basically its mesh configuration and its ID on the server). This information is retrieved via an audit packet in the Enterprise version of the console.
To retrieve the audit information (and perform the initial deployment of the mesh client), you can download the tis-meshagent package [1] from the store and modify it to include your server information and the custom installer for your mesh server.
Once the agent is installed, it will populate its audit data, and the "Access with mesh" button will be available.
Regards,
https://store.wapt.fr/store/tis-meshagent
infocfd
April 25, 2022 - 2:07 PM
Hi Denis,
thanks for your reply, it's all good for us, it works perfectly. We were just using an older mesh-agent package.
Have a good day everyone,
Denis V,
CGT Confederation
