CSV file formatting for machine import
florian777
Registration: Apr 13, 2022 - 09:53
April 15, 2022 - 10:00
I wanted to know how the CSV file used to import new machines for OS deployment should be formatted?
Thank you.
bkolovljanovic
Registration: Apr 20, 2022 - 2:26 p.m.
April 20, 2022 - 2:49 PM
Hello Florian,
Here is the list of possible elements in the CSV file.
"hostname";"mac_addresses";"status";"waiting_to_deploy";"product_key";"deploy_config_name";"driver_bundle";"disk_format";"djoin";"manufacturer";"uuid";"product";"serial_number"
At a minimum, it is necessary
Multiple MAC addresses can be entered, in the following format:
"xx:xx:xx:xx:xx:xx,xx:xx:xx:xx:xx:xx"
Good luck ;)
