Page 2 of 2
Re: Filing problem
Published: July 4, 2018 - 1:54 PM
by vince86
- Do you have any updates regarding version 1.6.0.4, which doesn't run on Windows Server 2016?
- Do you have any ideas about my 32/64 package issue?
Regards,
Re: Filing problem
Published: July 5, 2018 - 10:33 PM
by dcardon
Hello vince86,
vince86 wrote: ↑July 4, 2018 - 1:54 PM Hello,
- Do you have any news regarding version 1.6.0.4 which does not run under Windows 2016 Server?
- Do you have any idea regarding my 32/64 package problem?
I tested versions 1.6.2 nightly and 1.6.0.4 on a Windows Server 2016 and had no problems. When you perform your installation tests, are you using a local admin user or temporary privilege escalation?
The 32/64 package problem is a bug that was fixed in 1.6 and which I think should be fixed in the latest version 1.5.1.24.
Could you open two more threads for these issues? I think we can close this one.
Re: Filing problem
Published: July 9, 2018 - 11:53 PM
by vince86
I'm running version 1.6.0.4, which doesn't run on Windows Server 2016, using a domain admin account.
I'll test it with the 1.6.2 nightly build.
