Page 2 of 3
Re: Waptexit display bug under W10 1903
Published: September 30, 2019 - 09:03
by Mathieu
I installed a test machine with Windows 10 version 1903. The console correctly displays the machine, and I launch my pending packages. When I run a check, the console correctly displays all my packages that are waiting to be downloaded.
However, when I shut down or reboot, WAPTEXIT does not launch. I tried rebooting several times, but without success.
I performed a test by running waptexit.exe, and the installations then launched correctly.
Published: September 30, 2019 - 09:56
by sfonteneau
Does waptexit appear correctly in the shutdown scripts in the local GPO? (gpedit.msc)
Published: September 30, 2019 - 10:09 AM
by Mathieu
Yes, it does appear in the local GPO
Published: September 30, 2019 - 2:09 PM
by sfonteneau
And also in gpresult /h wapt.html?
Published: September 30, 2019 - 2:54 PM
by Mathieu
I don't have WAPT in the gpresult
Published: September 30, 2019 - 4:35 PM
by sfonteneau
and a gpupdate /force command?
You should have this:
Published: September 30, 2019 - 4:54 PM
by Mathieu
I tried it, and it tells me there's an application waiting, but it's a different application that isn't working. It appears in the event logs, but not Wapt; it's as if Wapt hasn't registered itself in the tasks
Published: September 30, 2019 - 5:03 PM
by sfonteneau
With Windows 10, I already encountered a case last week where a local GPO wouldn't apply because a domain GPO wasn't working...
:roll:
Published: October 1, 2019 - 2:19 PM
by Mathieu
I corrected the GPOs that were in error (damn SMB1 not enabled on W10) following that and the forced installation of the wapt-conf-policy
waptupgrade package to recreate the WAPTEXIT task launches with the display bug
Published: October 1, 2019 - 9:19 PM
by sfonteneau
Glad it's working again.
Mathieu wrote: ↑Oct 1, 2019 - 2:19 PM Damn SMB1
Joking aside, I'm very curious to know why you need to enable SMB1 on your Windows 10 :( :o :?
