Re: Criticism - Following update 1.7.4.6155, package management problems
Published: September 11, 2019 - 6:18 PM
Thank you for your reply, here are the results of the different commands I had already run:
The wapt-get.ini file:
The waptconsole.ini file:
An excerpt from debug mode:
The crt file: C:\Program Files (x86)\wapt\ssl\*.crt
The crt file: C:\Program Files (x86)\wapt\ssl\server\*.crt:
The crt certificate: C:\Program Files (x86)\wapt\private\*.crt:
The cert.pem file: /opt/wapt/waptserver/ssl/cert.pem:
Wapt server time:
and on the agent and console workstation:
However, the time displayed in Windows is 6:16 PM
Thank you for your help
C:\WINDOWS\system32>wapt-get update -f
Update package list from https://unc-srv-susi.cfu.local/wapt, https://unc-srv-susi.cfu.local/wapt-host
2019-09-11 17:46:06,059 CRITICAL Error merging Packages from https://unc-srv-susi.cfu.local/wapt-host into db: EWaptCertificateUnknownIssuer: None of certificates ("wapt-private","wapt-private") are trusted.
Total packages : 2
Added packages :
Removed packages :
Discarded packages count : 35
Pending operations :
upgrade:
additional:
install:
remove:
Repositories URL :
https://unc-srv-susi.cfu.local/wapt-hostCode: Select all
C:\WINDOWS\system32>wapt-get register
Registering host against server: https://unc-srv-susi.cfu.local
System Power Controls
Error when registering host against server https://unc-srv-susi.cfu.local: Error on server:
ExtensionNotFound('No <ObjectIdentifier(oid=2.5.29.14, name=subjectKeyIdentifier)> extension was found',)
[global]
repo_url=https://unc-srv-susi.cfu.local/wapt
send_usage_report=0
use_hostpackages=1
wapt_server=https://unc-srv-susi.cfu.local
use_kerberos=0
check_certificates_validity=1
verify_cert=0
dnsdomain=
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
host_profiles=
[wapt-templates]
verify_cert=1Code: Select all
[global]
send_usage_report=0
use_hostpackages=1
use_kerberos=0
verify_cert=C:\Program Files (x86)\wapt\ssl\server\unc-srv-susi.cfu.local.crt
dnsdomain=
hiberboot_enabled=0
host_profiles=
http_proxy=
default_package_prefix=si
default_sources_root=c:\waptdev
personal_certificate_path=c:\private\wapt-private.crt
use_http_proxy_for_server=0
use_http_proxy_for_repo=0
default_maturity=
grid_hosts_plugins=W10=
client_certificate=
client_private_key=
enable_external_tools=1
enable_management_features=1
hide_unavailable_actions=0
language=fr
advanced_mode=1
default_ca_cert_path=c:\private\wapt-private.crt
use_fqdn_as_uuid=0
use_ad_groups=0
[wapt-templates]
verify_cert=1
C:\WINDOWS\system32>"c:\Program Files (x86)\wapt\runwaptservice.bat" -ldebug
Le service WAPTService s’arrête.
Le service WAPTService a été arrêté.
2019-09-11 17:57:59,180 DEBUG Thread 45352 is connecting to wapt db
2019-09-11 17:57:59,283 DEBUG Thread 45352 is connecting to wapt db
2019-09-11 17:57:59,285 DEBUG DB Start transaction
2019-09-11 17:57:59,286 DEBUG DB commit
2019-09-11 17:57:59,290 DEBUG Thread 45352 is connecting to wapt db
2019-09-11 17:57:59,375 DEBUG Thread 45352 is connecting to wapt db
2019-09-11 17:57:59,375 DEBUG DB Start transaction
2019-09-11 17:57:59,378 DEBUG DB commit
2019-09-11 17:57:59,378 INFO Starting task queue
2019-09-11 17:57:59,380 INFO Task queue running
2019-09-11 17:57:59,381 INFO Reloading configuration
2019-09-11 17:57:59,403 INFO starting waptservice
2019-09-11 17:57:59,404 INFO Starting Rocket 1.2.8
2019-09-11 17:57:59,404 INFO No password set for local waptservice, using local computer security
2019-09-11 17:57:59,404 DEBUG This platform does not support signals.
2019-09-11 17:57:59,405 DEBUG Starting threads.
2019-09-11 17:57:59,407 DEBUG Growing by 10.
2019-09-11 17:57:59,410 DEBUG Entering main loop.
2019-09-11 17:57:59,411 DEBUG Entering main loop.
2019-09-11 17:57:59,414 DEBUG Entering main loop.
2019-09-11 17:57:59,415 DEBUG Entering main loop.
2019-09-11 17:57:59,417 DEBUG Entering main loop.
2019-09-11 17:57:59,418 DEBUG Entering main loop.
2019-09-11 17:57:59,420 DEBUG Entering main loop.
2019-09-11 17:57:59,421 DEBUG Entering main loop.
2019-09-11 17:57:59,424 DEBUG Entering main loop.
2019-09-11 17:57:59,426 DEBUG Thread 46116 is connecting to wapt db
2019-09-11 17:57:59,426 DEBUG Entering main loop.
2019-09-11 17:57:59,427 INFO Listening on sockets: 127.0.0.1:8088
2019-09-11 17:57:59,427 DEBUG Entering monitor loop.
2019-09-11 17:57:59,428 DEBUG Entering main loop.
2019-09-11 17:57:59,430 DEBUG Thread 45252 is connecting to wapt db
2019-09-11 17:57:59,687 DEBUG Thread 45252 is connecting to wapt db
2019-09-11 17:57:59,688 DEBUG Thread 46116 is connecting to wapt db
2019-09-11 17:57:59,688 DEBUG DB Start transaction
2019-09-11 17:57:59,690 DEBUG DB Start transaction
2019-09-11 17:57:59,690 DEBUG DB commit
2019-09-11 17:57:59,693 INFO Starting socketio on "https://unc-srv-susi.cfu.local:443" ...
2019-09-11 17:57:59,693 INFO Wapt tasks management initialized with c:\Program Files (x86)\wapt\wapt-get.ini configuration, thread ID 46116
2019-09-11 17:57:59,694 DEBUG Certificate checking : False
2019-09-11 17:57:59,694 DEBUG Wapt tasks queue started
2019-09-11 17:57:59,694 DEBUG Checking if config file has changed
2019-09-11 17:57:59,868 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:00,019 DEBUG https://unc-srv-susi.cfu.local:443 "POST /get_websocket_auth_token HTTP/1.1" 200 302
2019-09-11 17:58:00,022 WARNING Websocket connect params: Unable to get auth token: Error on server:
EWaptAuthenticationFailure(u"Request signature verification failed: SSL signature verification failed for certificate {'commonName': u'4C4C4544-0044-5110-8038-B1C04F344632'} issued by unc-srv-susi.cfu.local",)
2019-09-11 17:58:00,105 DEBUG Creating socketio client
2019-09-11 17:58:00,105 DEBUG Proxies : {'http': None, 'https': None}
2019-09-11 17:58:00,105 DEBUG New waptremotecall instance created...
2019-09-11 17:58:00,119 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:00,263 DEBUG https://unc-srv-susi.cfu.local:443 "GET /socket.io/?uuid=4C4C4544-0044-5110-8038-B1C04F344632&EIO=3&transport=polling&t=1568217480109-0 HTTP/1.1" 200 119
2019-09-11 17:58:00,430 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
unc-srv-susi.cfu.local:443/socket.io [engine.io transport selected] websocket
2019-09-11 17:58:01,359 DEBUG unc-srv-susi.cfu.local:443/socket.io [engine.io transport selected] websocket
unc-srv-susi.cfu.local:443/socket.io [heartbeat reset]
2019-09-11 17:58:01,362 DEBUG unc-srv-susi.cfu.local:443/socket.io [heartbeat reset]
unc-srv-susi.cfu.local:443/socket.io [socket.io packet sent] 2["wapt_pong"]
2019-09-11 17:58:01,365 DEBUG unc-srv-susi.cfu.local:443/socket.io [socket.io packet sent] 2["wapt_pong"]
2019-09-11 17:58:01,368 INFO Socket IO listening for 120s
2019-09-11 17:58:01,433 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:02,434 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:03,436 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:04,437 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:05,440 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:06,443 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:07,444 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:08,447 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:09,450 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:09,868 INFO Status :
2019-09-11 17:58:09,868 DEBUG DB Start transaction
2019-09-11 17:58:09,878 DEBUG DB commit
2019-09-11 17:58:09,888 DEBUG Check scheduled tasks
2019-09-11 17:58:09,890 DEBUG DB Start transaction
2019-09-11 17:58:09,894 DEBUG DB commit
2019-09-11 17:58:10,082 DEBUG DB Start transaction
2019-09-11 17:58:10,451 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:10,553 DEBUG Remove unknown repositories from packages table and params ("wapt","wapt-host")
2019-09-11 17:58:10,555 DEBUG Check last-modified header for wapt to avoid unecessary update
2019-09-11 17:58:10,555 DEBUG Checking availability of https://unc-srv-susi.cfu.local/wapt/Packages
2019-09-11 17:58:10,556 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:10,684 DEBUG https://unc-srv-susi.cfu.local:443 "HEAD /wapt/Packages HTTP/1.1" 200 0
2019-09-11 17:58:10,687 INFO Index from wapt has not been updated (last update 2019-09-11T11:02:46), skipping update
2019-09-11 17:58:10,687 DEBUG Check last-modified header for wapt-host to avoid unecessary update
2019-09-11 17:58:10,688 DEBUG Checking availability of wapt-host
2019-09-11 17:58:10,691 DEBUG Trying to get host package for 4C4C4544-0044-5110-8038-B1C04F344632 at https://unc-srv-susi.cfu.local/wapt-host/4C4C4544-0044-5110-8038-B1C04F344632.wapt
2019-09-11 17:58:10,694 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:10,825 DEBUG https://unc-srv-susi.cfu.local:443 "HEAD /wapt-host/4C4C4544-0044-5110-8038-B1C04F344632.wapt HTTP/1.1" 200 0
2019-09-11 17:58:10,828 INFO Index from wapt-host has not been updated (last update 2019-09-09T08:59:45), skipping update
2019-09-11 17:58:10,838 DEBUG DB commit
2019-09-11 17:58:10,993 DEBUG Checking availability of host packages "[PackageEntry(u'4C4C4544-0044-5110-8038-B1C04F344632',u'26' )]"
2019-09-11 17:58:10,993 DEBUG Checking if 4C4C4544-0044-5110-8038-B1C04F344632(=26) is installed/outdated
2019-09-11 17:58:11,128 DEBUG store status in DB
2019-09-11 17:58:11,128 DEBUG DB Start transaction
2019-09-11 17:58:11,135 DEBUG DB commit
2019-09-11 17:58:11,262 DEBUG Checking availability of host packages "[PackageEntry(u'4C4C4544-0044-5110-8038-B1C04F344632',u'26' )]"
2019-09-11 17:58:11,263 DEBUG Checking if 4C4C4544-0044-5110-8038-B1C04F344632(=26) is installed/outdated
2019-09-11 17:58:11,265 DEBUG 2019-09-11 17:58:11.265000 i'm still alive... but nothing to do
2019-09-11 17:58:11,265 DEBUG Checking if config file has changed
2019-09-11 17:58:11,381 DEBUG Checking if old install in progress
2019-09-11 17:58:11,459 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:12,519 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:13,068 DEBUG reset stalled install_status in database
Get packages index
2019-09-11 17:58:13,073 DEBUG DB Start transaction
2019-09-11 17:58:13,082 DEBUG DB commit
2019-09-11 17:58:13,223 DEBUG DB Start transaction
2019-09-11 17:58:13,223 DEBUG Remove unknown repositories from packages table and params ("wapt","wapt-host")
2019-09-11 17:58:13,224 DEBUG Check last-modified header for wapt to avoid unecessary update
2019-09-11 17:58:13,226 DEBUG Checking availability of https://unc-srv-susi.cfu.local/wapt/Packages
2019-09-11 17:58:13,226 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:13,352 DEBUG https://unc-srv-susi.cfu.local:443 "HEAD /wapt/Packages HTTP/1.1" 200 0
2019-09-11 17:58:13,355 INFO Index from wapt has not been updated (last update 2019-09-11T11:02:46), skipping update
2019-09-11 17:58:13,355 DEBUG Check last-modified header for wapt-host to avoid unecessary update
2019-09-11 17:58:13,357 DEBUG Checking availability of wapt-host
2019-09-11 17:58:13,358 DEBUG Trying to get host package for 4C4C4544-0044-5110-8038-B1C04F344632 at https://unc-srv-susi.cfu.local/wapt-host/4C4C4544-0044-5110-8038-B1C04F344632.wapt
2019-09-11 17:58:13,361 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:13,489 DEBUG https://unc-srv-susi.cfu.local:443 "HEAD /wapt-host/4C4C4544-0044-5110-8038-B1C04F344632.wapt HTTP/1.1" 200 0
2019-09-11 17:58:13,490 INFO Index from wapt-host has not been updated (last update 2019-09-09T08:59:45), skipping update
2019-09-11 17:58:13,500 DEBUG DB commit
2019-09-11 17:58:13,569 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:13,667 DEBUG Checking availability of host packages "[PackageEntry(u'4C4C4544-0044-5110-8038-B1C04F344632',u'26' )]"
2019-09-11 17:58:13,667 DEBUG Checking if 4C4C4544-0044-5110-8038-B1C04F344632(=26) is installed/outdated
2019-09-11 17:58:13,670 DEBUG store status in DB
2019-09-11 17:58:13,670 DEBUG DB Start transaction
2019-09-11 17:58:13,677 DEBUG DB commit
2 paquet(s) dans le dépôt
Le système est à jour
2019-09-11 17:58:13,687 INFO Status : Done: Mise à jour de la liste des paquets disponibles
2019-09-11 17:58:13,687 DEBUG DB Start transaction
2019-09-11 17:58:13,688 DEBUG DB commit
2019-09-11 17:58:13,696 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:13,826 DEBUG https://unc-srv-susi.cfu.local:443 "HEAD /ping HTTP/1.1" 200 0
2019-09-11 17:58:13,831 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:13,963 DEBUG https://unc-srv-susi.cfu.local:443 "HEAD /ping HTTP/1.1" 200 0
2019-09-11 17:58:14,572 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:14,733 DEBUG DB Start transaction
2019-09-11 17:58:14,734 DEBUG DB commit
2019-09-11 17:58:14,746 DEBUG Stores cert chain check in cache
2019-09-11 17:58:15,095 INFO Updated data keys : ['host_metrics', 'wapt_status', 'host_info', 'last_update_status', 'host_capabilities', 'installed_softwares', 'audit_status', 'installed_packages', 'authorized_certificates']
2019-09-11 17:58:15,098 INFO Supplied data keys : ['last_update_status', 'host_metrics', 'uuid', 'host_info', 'installed_softwares', 'status_revision', 'host_capabilities', 'wapt_status', 'status_hashes', 'audit_status', 'installed_packages', 'authorized_certificates']
2019-09-11 17:58:15,173 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:15,569 DEBUG https://unc-srv-susi.cfu.local:443 "POST /update_host HTTP/1.1" 200 247
2019-09-11 17:58:15,572 INFO Error updating Status on server https://unc-srv-susi.cfu.local: Error on server:
SSLVerifyException(u"SSL signature verification failed for certificate {'commonName': u'4C4C4544-0044-5110-8038-B1C04F344632'} issued by unc-srv-susi.cfu.local",)
2019-09-11 17:58:15,572 WARNING Host on the server is not known or not known under this FQDN name (known as None). Trying to register the computer...
2019-09-11 17:58:15,573 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:15,573 DEBUG DB Start transaction
2019-09-11 17:58:15,578 DEBUG DB commit
2019-09-11 17:58:15,714 DEBUG DB Start transaction
2019-09-11 17:58:15,723 DEBUG DB commit
2019-09-11 17:58:15,730 DEBUG DB Start transaction
2019-09-11 17:58:15,732 DEBUG DB commit
2019-09-11 17:58:16,134 DEBUG DB Start transaction
2019-09-11 17:58:16,142 DEBUG DB commit
2019-09-11 17:58:16,576 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:17,578 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:18,579 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:19,581 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:20,582 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:21,584 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:22,585 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:23,585 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:24,588 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:25,588 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:26,028 INFO Run "dmidecode -q"
2019-09-11 17:58:26,059 INFO dmidecode -q command returns code 0
2019-09-11 17:58:26,380 DEBUG Starting new HTTPS connection (1): unc-srv-susi.cfu.local:443
2019-09-11 17:58:26,589 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:27,125 DEBUG https://unc-srv-susi.cfu.local:443 "POST /add_host HTTP/1.1" 200 187
2019-09-11 17:58:27,127 CRITICAL Error on server:
2019-09-11 17:58:27,128 CRITICAL Unable to update server status: Error on server:
2019-09-11 17:58:27,128 INFO Status :
2019-09-11 17:58:27,131 DEBUG DB Start transaction
2019-09-11 17:58:27,140 DEBUG DB commit
2019-09-11 17:58:27,148 DEBUG Checking if config file has changed
2019-09-11 17:58:27,592 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:28,594 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:29,595 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:30,596 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:31,599 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:32,601 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:33,605 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:34,607 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:35,608 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:36,611 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:37,296 INFO Status :
2019-09-11 17:58:37,298 DEBUG DB Start transaction
2019-09-11 17:58:37,308 DEBUG DB commit
2019-09-11 17:58:37,319 DEBUG Check scheduled tasks
2019-09-11 17:58:37,321 DEBUG 2019-09-11 17:58:37.321000 i'm still alive... but nothing to do
2019-09-11 17:58:37,321 DEBUG Checking if config file has changed
2019-09-11 17:58:37,612 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:38,615 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:39,618 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:40,619 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:41,621 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:42,624 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:43,625 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:44,628 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:45,630 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:46,631 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:47,483 INFO Status :
2019-09-11 17:58:47,483 DEBUG DB Start transaction
2019-09-11 17:58:47,492 DEBUG DB commit
2019-09-11 17:58:47,500 DEBUG Check scheduled tasks
2019-09-11 17:58:47,500 DEBUG 2019-09-11 17:58:47.501000 i'm still alive... but nothing to do
2019-09-11 17:58:47,500 DEBUG Checking if config file has changed
2019-09-11 17:58:47,632 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:48,634 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:49,575 INFO Stopping Rocket 1.2.8
2019-09-11 17:58:49,635 DEBUG Examining ThreadPool. 10 threads and 0 Q'd conxions
2019-09-11 17:58:50,480 DEBUG Listener exiting.
2019-09-11 17:58:50,480 DEBUG Flushing waiting connections
2019-09-11 17:58:50,482 DEBUG Flushing queued connections
2019-09-11 17:58:50,638 DEBUG Stopping threads.
2019-09-11 17:58:50,640 DEBUG Shrinking by 10.
2019-09-11 17:58:50,641 DEBUG Received a death threat.
2019-09-11 17:58:50,642 DEBUG Received a death threat.
2019-09-11 17:58:50,644 DEBUG Received a death threat.
2019-09-11 17:58:50,645 DEBUG Received a death threat.
2019-09-11 17:58:50,648 DEBUG Received a death threat.
2019-09-11 17:58:50,650 DEBUG Received a death threat.
2019-09-11 17:58:50,661 DEBUG Removing dead thread: Thread-4.
2019-09-11 17:58:50,664 DEBUG Removing dead thread: Thread-12.
2019-09-11 17:58:50,665 DEBUG Removing dead thread: Thread-10.
2019-09-11 17:58:50,667 DEBUG Removing dead thread: Thread-7.
2019-09-11 17:58:50,667 DEBUG Removing dead thread: Thread-9.
2019-09-11 17:58:50,668 DEBUG Removing dead thread: Thread-13.
2019-09-11 17:58:50,671 DEBUG Removing dead thread: Thread-8.
2019-09-11 17:58:50,673 DEBUG Removing dead thread: Thread-11.
2019-09-11 17:58:50,674 DEBUG Removing dead thread: Thread-5.
2019-09-11 17:58:50,676 DEBUG Removing dead thread: Thread-6.
2019-09-11 17:58:57,619 INFO Status :
2019-09-11 17:58:57,621 DEBUG DB Start transaction
2019-09-11 17:58:57,634 DEBUG DB commit
2019-09-11 17:58:57,644 DEBUG Check scheduled tasksCode: Select all
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----Code: Select all
# CN: unc-srv-susi.cfu.local
# Issuer CN: unc-srv-susi.cfu.local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mer. sept. 11 18:16:56 CEST 2019Code: Select all
datetime.datetime(2019, 9, 11, 16, 16, 26, 988000)Thank you for your help
