Page 2 of 2
Re: Custom TeamViewer Package
Published: November 20, 2019 - 7:27 AM
by Smart
Just the software, not the settings.
Published: November 20, 2019 - 09:43
by Gaetan
I found this page, it might help you:
https://community.teamviewer.com/t5/Kno ... ta-p/39639
Published: November 25, 2019 - 7:54 AM
by Smart
I did this:
destdir = makepath('C:\\','TeamViewer')
msifile = makepath(destdir,'TeamViewer_Host.msi')
    print('installing muller-teamviewer-14-host')
    mkdirs(destdir)
    copytree2(r'Config',destdir)
    run(r'msiexec.exe /i "C:\TeamViewer\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=****APITOKEN=**** ASSIGNMENTOPTIONS="--reassign --alias %COMPUTERNAME%"')
For now, I've managed to link it to the company account but haven't been able to set a password. I'm continuing to work on it and will keep you updated.
Published: November 25, 2019 - 3:01 PM
by Smart
FINAL CODE:
    mkdirs(destdir)
    run(r'msiexec.exe /i "C:\TeamViewer\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=****APITOKEN=**** ASSIGNMENTOPTIONS="--grant-easy-access --reassign --alias %COMPUTERNAME%"')
    killalltasks('TeamViewer.exe')
    remove_file(exefile)
    remove_tree(destdir)
    run(r'"C:\Program Files (x86)\TeamViewer\uninstall.exe"')
I can't set a custom password, but that's normal. With the option
--grant-easy-access
I can take control without knowing the password.
Re: [SOLVED] Custom TeamViewer Package
Published: November 25, 2019 - 3:07 PM
by Gaetan
Very good then ;)
Published: March 28, 2020 - 8:11 PM
by TheMax
Hello everyone, as I'm new to the forum and to using WAPT, I wanted to try my hand at a small script for a custom installation of TeamViewer Host as an .exe file
    install_exe_if_needed("host.exe",'/S',key='',min_version='15.4.4445.0')
    run(r'"C:\Program Files (x86)\TeamViewer\Teamviewer.exe" assign --api-token 1122-ZBDHZKBDDD --alias %COMPUTERNAME% --grant-easy-access')
I'm having trouble with this code; I can't uninstall it using uninstallkey. Does anyone have any ideas?
The Max
