Page 2 of 2
Re: WAPT 1.8 - WaptService is not installed
Published: July 1, 2020 - 12:32 PM
by sfonteneau
You can try restarting the installation with the following command in an administrator command prompt:
cd "c:\Program Files (x86)\wapt"
waptpython waptservice\service.py install
Published: July 1, 2020 - 12:43 PM
by William12
sfonteneau wrote: ↑July 1, 2020 - 12:32 You can try restarting the installation with the following command in an administrator command prompt:
Here is the result of the command:
	File "waptservice\service.py, line 95, in <module>
		from common import Wapt
ImportError: cannot import name Wapt
Published: July 1, 2020 - 1:53 PM
by sfonteneau
Yes, I've just reproduced the problem.
We no longer have the issue with wapt-get.exe, but the PYTHONHOME environment variable is still causing problems.
I've opened an internal ticket to resolve this issue.
Published: July 1, 2020 - 2:14 PM
by William12
Okay, great, thanks.
I'll keep an eye out for future updates. :)
Published: November 19, 2020 - 1:24 PM
by William12
I haven't had a chance to check for any upcoming updates yet. But can we expect a fix for the problem mentioned above?
William
