Page 2 of 3
Re: WAPT and MS Office
Published: March 15, 2016 - 2:41 PM
by a.grisard
So, when I run the command manually: The launcher appears with the choice between Install and Custom.
When I choose Install, I get the configuration I entered in my MSP file (the license, the installation without access).
But I just realized my mistake: I put my MSP in the UPDATES folder, and now when I select the "install now" button, the installation starts. So, can I try a WAPT package again?
Published: March 15, 2016 - 2:53 PM
by sfonteneau
That explains your problem.
You can therefore try a WAPT package again.
Published: March 15, 2016 - 5:25 PM
by a.grisard
I just tried the manual command "setup.exe /adminfile "install_sans_access.msp" and it worked. However, the window (office) appears and disappears.
When I run my package on my machine, I get information that the task is complete but nothing is installed.
When I go into the Temp files, I get the following log:
PERF: TickCount=1506718 Name=OBootStrapper::Run Description=Begin function
Operating System version: 6.1.7601 Service Pack 1. Platform ID: 2
Running on a 64-bit operating system.
Command line: "setup.exe" /adminfile "install_sans_access.MSP"
Parsing command line.
Admin patch file/path specified: c:\windows\temp\wapthsykwx\install_sans_access.MSP
Verify file signature in "c:\windows\temp\wapthsykwx\SETUP.EXE"
Verify file signature in "c:\windows\temp\wapthsykwx\PROPLUS.WW\OSETUP.DLL"
Using setup controller dll at [c:\windows\temp\wapthsykwx\PROPLUS.WW\OSETUP.DLL].
PERF: TickCount=1509078 Name=OBootStrapper::Run Description=Calling RunSetup
Opening log file C:\Windows\TEMP\SetupExe(201603151634055FC).log.
PERF: TickCount=1509093 Name=RunSetup Description=Begin function
Catalyst execution began: 03/15/2016 16:34:05.
Setupexe Resiliency Mode is set to [PerformIfApplicable]; thus Resiliency is [disabled] for the [InstallExecutionMode]
Searching for updated versions of resource files under the 'updates' folder [c:\windows\temp\wapthsykwx\updates].
Found [0] resource files under the update folder.
Searching for default versions of resource files under the folder [c:\windows\temp\wapthsykwx].
Resource File Manager : Found (CultureTag=fr-FR) resource file at [c:\windows\temp\wapthsykwx\OFFICE.FR-FR\OSETUPUI.DLL].
Found [1] resource files under the default folder.
Resource File Manager : Current user's LCID is [1036].
Resource File Manager : Selecting resource file (File=c:\windows\temp\wapthsykwx\OFFICE.FR-FR\OSETUPUI.DLL) for CultureTag [fr-FR].
Running in [InstallExecutionMode]. Run from TEMP folder at [C:\Windows\TEMP\Setup000005fc].
Loaded resource file [C:\Windows\TEMP\Setup000005fc\OSETUPUI.DLL] (CultureTag=fr-FR).
Loaded Dll : c:\windows\temp\wapthsykwx\PROPLUS.WW\OSETUP.DLL.
Catalyst version is : 12.0.4518.1014
JobExecutionMode is InstallExecutionMode.
LIS: start parsing setup xml
LIS: finished parsing LIS package "{90120000-0015-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-0016-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-0044-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-006E-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-002A-040C-1000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-001A-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-0018-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-002C-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-0011-0000-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-0019-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-0010-040C-0000-0000000FF1CE}"
LIS: finished parsing LIS package "{90120000-001B-040C-0000-0000000FF1CE}"
Product: PROPLUS
AddOnGroup Culture: fr-fr
AddOnId: OFFICE.FR-FR
AddOnId: ACCESS.FR-FR
AddOnId: WORD.FR-FR
AddOnId: PUBLISHER.FR-FR
AddOnId: PROOFING.FR-FR
AddOnId: OFFICE64.FR-FR
AddOnId: INFOPATH.FR-FR
AddOnId: POWERPOINT.FR-FR
AddOnId: OUTLOOK.FR-FR
AddOnId: EXCEL.FR-FR
Published: March 16, 2016 - 08:59
by sfonteneau
The logs don't tell me anything.
If the command `setup.exe /adminfile "install.msp"` succeeds when you test it manually (without any manual intervention on your part), but your WAPT package doesn't work, that's quite strange.
Published: March 16, 2016 - 10:58
by a.grisard
Here's my procedure:
1) I run the "setup /admin" command to create my MSP configuration file.
2) I create a package with the command "wapt-get make-template path\setup.exe".
3) I modify my Python files as described above.
4) I run the package build with "wapt-get build-upload path\aiz-office2007-wapt".
5) The package automatically uploads to my repositories.
6) I associate it with a machine.
7) I run a package update and installation on that machine.
I just succeeded!! I'm now going to try your uninstallation procedure.
Published: March 17, 2016 - 2:42 PM
by a.grisard
I'm having some trouble uninstalling.
I understand that I need to insert an "uninstall.xml" file, but I don't understand how it works.
I added this to my Python script: "uninstallstring = 'MsiExec.exe /qn /X{90120000-0011-0000-0000-0000000FF1CE}'" without success.
Any ideas?
Published: March 17, 2016 - 10:05 PM
by sfonteneau
Here is the content of the uninstall.xml file for Office Pro Plus:
<Configuration Product="ProPlus">
<Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" />
<Setting Id="SETUP_REBOOT" Value="NEVER" />
</Configuration>
Here is the uninstall string that I specify at the top of setup.py:
uninstallstring =['"%s\Common Files\microsoft shared\OFFICE15\Office Setup Controller\Setup.exe" /uninstall ProPlus /config "%s\Common Files\uninstall.xml"' % (programfiles32,programfiles32) ]
Note that for the uninstall to work, the file must be copied to %programfiles%\Common Files\
I copy it using this command during software installation:
filecopyto("uninstall.xml",os.path.join(programfiles32,"Common Files"))
Published: March 24, 2016 - 11:51
by a.grisard
I'm writing to let you know that I've successfully deployed and uninstalled my Office 2007 package.
Now I need to uninstall the existing Microsoft Office Professional installation and replace it with Office Standard 2007. Is this possible?
I tried creating a new Office Standard package, but it doesn't reinstall Office; it copies it alongside the existing installation. So I have two entries in Windows, and Access is still present.
Published: March 24, 2016 - 1:04 PM
by sfonteneau
When creating the MSP, it is normally possible to check "Uninstall previous versions of Microsoft Office".
Otherwise, you have to resort to scripting the uninstallations.
Published: March 24, 2016 - 2:02 PM
by a.grisard
The problem is that it does not recognize the already installed version of Office Pro; it adds a program line in Office Standard and therefore does not uninstall Access.
