Page 2 of 3
Re: [BUG 2.1 ??] Machines seen as DISCONNECTED since update 2.1
Published: October 25, 2021 - 4:41 PM
by Christophe0110
Thanks for your reply jc35, I'm looking forward to your feedback on the Nightly build.
Cheers!
Published: October 26, 2021 - 1:42 PM
by jc35
after some testing, it's better; I no longer get random disconnections, especially right after installing a package.
However, when I unplug the network cable, it still shows as disconnected even though it's connected via Wi-Fi.
Published: October 26, 2021 - 2:47 PM
by Christophe0110
Thanks for your feedback!
Yes, so in my opinion, my problem won't be solved since this is what happens in my case when the user leaves their docking station (connected via a network cable) and therefore switches to Wi-Fi to go to the meeting room...
I suppose we have to wait for a resolution to the problem (even if it's starting to take a long time after 2 weeks now...).
Published: October 26, 2021 - 3:18 PM
by jc35
Indeed. I restarted the service and it reconnected, then I reconnected the network cable, and it disconnected again.
So it's not completely resolved.
Yes, it's starting to take a long time. There's a slight improvement.
Next test(s) in the build(s).
Published: October 27, 2021 - 09:01
by Christophe0110
Thanks for your help, jc35.
Hopefully, this problem will be resolved quickly by the WAPT Team...
In the meantime, I created a small batch file that allows me to remotely restart the WAPT services for each machine displaying "DISCONNECTED"...
But it's a pain.
Published: October 28, 2021 - 5:25 PM
by jpatrizio
Hello everyone,
I have a Debian 10 VM with Wapt 2.1.10550.
I'm experiencing the same problem as you,
namely disconnected workstations.
I also have another problem with OUs: an error value = -1 when attempting to edit the packet for this OU.
Jean-Philippe.
Published: November 2, 2021 - 10:49 AM
by Christophe0110
I see there are new nightly builds since jc35's test.
Personally, I don't feel like testing them...
Is there somewhere we can see the changes and fixes included in these nightly builds?
For example, in this release version changelog:
https://www.wapt.fr/fr/doc/wapt-changelog.html
Cheers!
Published: November 2, 2021 - 11:37 AM
by sfonteneau
indeed we wanted to limit database access using WebSockets, but this is clearly causing problems.
Overall, we have an issue with the WebSocket library we're using.
While waiting for a patch (which should arrive shortly), you can use the "Tools->Reset WebSocket Connections" button in the console. This will reset the connection on the machines selected in the grid.
This forces the machines to reconnect.
We've identified a second potential problem: by default, the WAPT agent restarts automatically every day (24 hours).
To do this, we use a scheduled task that runs `net stop waptservice` and `net start waptservice`. This scheduled task is created automatically if the service has been running for more than 24 hours. It seems that sometimes the stop command fails, and the start command doesn't follow. The service therefore remains stopped.
We'd need to determine if you're experiencing the first or second scenario.
- Simon
Published: November 2, 2021 - 11:46 AM
by ncaillaud
I have exactly the same problem with about a third of our deployed machines.
The error logs are almost always the same:
CRITICAL Error merging
Packages from wapt into db: None: None
CRITICAL Error merging Packages from wapt-host into db: None: None
WARNING Websocket connect params: HTTPSConnectionPool(host='wapt.XXX.fr', port=443): Max retries exceeded with url: /get_websocket_auth_token (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
WARNING Websocket connect params: Unable to get auth token: Error on server:
EWaptAuthenticationFailure('Unknown host UUID XXXXX. Please register first.')
I am currently on the latest version of the WAPT agent, 2.1.
Published: November 2, 2021 - 2:22 PM
by Christophe0110
sfonteneau wrote: ↑Nov 2, 2021 - 11:37 AM Hello,
Indeed, we wanted to limit database access using WebSockets, but this is clearly causing problems.
While waiting for a patch (which should arrive soon), you can use the "Tools->Reset WebSocket Connections" button in the console. This will reset the connection on the machines selected in the grid.
To do this, we use a scheduled task that runs `net stop waptservice` and `net start waptservice`. This scheduled task is created automatically if the service has been running for more than 24 hours. It seems that sometimes the stop fails and the start fails. The service therefore remains stopped.
We'd need to see if you're experiencing the first or second scenario.
I could be in both cases but in my opinion, I am more in the first case because the positions concerned are mostly laptops (so they do not stay on for 24 hours, in theory).
But I'll test the button in the console; it'll help me while I wait for a fix...
Christophe.
