Page 2 of 2
Re: [WAPT 2.2] Template install MSI error
Published: July 19, 2022 - 3:29 PM
by HugoDams
dcardon wrote: ↑Jul 19, 2022 - 2:16 PM Does the installer need network resources to finish its installation (any file sharing on a server)?
No.
dcardon wrote: ↑Jul 19, 2022 - 2:16 PM Could you check if the solution offered by Autodesk can solve your problem?
What do you mean by Autodesk's solution? Atlas is a specific data processing software developed by McLaren:
https://www.mclarenapplied.com/products ... ion-system
Version 9 has an MSI file, so I thought it would be simpler than Atlas10 which is only in .exe format (I haven't looked into it yet)
Hugo
Published: July 19, 2022 - 3:51 PM
by dcardon
Basically, if your software doesn't require a connection to a network share to complete its installation, the error message is probably incorrect and appears for many other software programs when installed using a Local System account (including Autodesk, but quite a few others as well).
Published: July 19, 2022 - 4:05 PM
by HugoDams
Damn! Do you know if this problem occurs on all versions of Windows?
Is there no other way to install it as a package?
Hugo
Published: July 19, 2022 - 4:51 PM
by dcardon
Alternatively, if you have a more recent executable version, you can try that one; with WAPT, it doesn't change much in terms of packaging complexity compared to an MSI.
