Page 2 of 2
Re: Visualizing encrypted audit data
Published: February 9, 2026 - 7:23 PM
by Kevin-LH76
The register hasn't changed anything and the problem is present for all machines that report this audit.
Published: February 10, 2026 - 09:41
by sfonteneau
    WAPT.write_audit_data_if_changed("test-encryption", 'test-encryption', rsa_encrypted_data_str("test", WAPT.public_certs_dir), max_count=365)
Could you try creating this package for testing purposes and installing it on a machine?
Published: February 10, 2026 - 1:37 PM
by Kevin-LH76
The data is being retrieved correctly:
	"id": 4042,
	"host": "XXX",
	"value_id": 3802606994107531265,
	"value_date": "2026-02-10T12:34:28.809306+00:00",
	"value_section": "test-encryption",
	"value_key": "test-encryption",
	"value": "-----BEGIN WAPT ENCRYPTION-----{\"a4e7e9bfc90cc0341f49190ffa8b6286e6e3399101c1655786e00d6e1b125f4f\": \"\", \"8e37dadb40b20f54e6311e7cb08d1db72358705f70ba15eeb953e9a58822466c\": \"\", \"a98863744cb96008fe4ef33909d54d8483ab1bd5c1d707b8c5c65877befb480f\": \"\", \"02428060cfda0b56e2af47ba032cf627a59e2b7e542ce6638f74a16bfa4ee380\": \"\", \"045af5a016701f07c205e2831b0a164016dcd9c66e2bfdadbf4deefe0d0e82b8\": \"\"}-----END WAPT ENCRYPTION-----",
	"expiration_date": null,
	"created_on": "2026-02-10T12:34:25.618810",
	"created_by": null,
	"computer_fqdn": "XX",
	"description": null,
	"server_name": "XXX"
But the "Decrypt data" action does nothing
